Go to Post Let this be a hint to the hardware teams. Deliver that robot early and give the software and driving team time with the robot. IR3 has proven it can be done. - Doug Leppard [more]
Unread 14-02-2014, 19:14
pflanagan pflanagan is offline
Head Coach
FRC #5000 (Hammerheads)
pflanagan is an unknown quantity at this point
Linear Actuator
Would this linear actuator be legal to use?
http://www.actuatorzone.com/actuator...-actuator.aspx
Unread 14-02-2014, 19:32
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
Re: Linear Actuator
I'm thinking no, because the motor inside of it isn't included in the list in the manual (scroll down to 4.7).
Unread 14-02-2014, 19:39
Dan_Karol Dan_Karol is offline
Mentor and Coach
AKA: Daniel Karol
FRC #0131 (CHAOS)
Dan_Karol has a spectacular aura aboutDan_Karol has a spectacular aura about
Send a message via AIM to Dan_Karol
Re: Linear Actuator
No,
R29 states:
The only motors and actuators permitted on 2014 FRC ROBOTS include the following:
CIM - 6
BaneBots Motors - 4
AndyMark 9015 - 4
Denso Throttle Control - 4
VEX BAG and/or mini-CIM - 4
AndyMark PG - 3
Window Motors/Door Motors/Windshield Wiper Motors/Seat Motors - 2
VEX 2-wire Motor 393 - 2
Snow Blower Motor - 1
As well as unlimited numbers of:
Electrical solenoid actuators, no greater than 1 in. stroke and rated electrical input power no greater than 10 watts (W) continuous duty at 12 volts (VDC)
Drive motors or fans that are part of a motor controller or COTS computing device
Fans included in the 2014 Kickoff Kit, FIRSTŪ Choice, or as a Talon motor controller accessory
COTS servos with a maximum power rating of 4W each at 6VDC
Per the Servo Industry,
Servo Max Power Rating = (Stall Torque) X (No Load Speed)
That actuator contains a build in motor that is not on the list. For more information please visit the FIRST 2014 manual at: http://frc-manual.usfirst.org/viewItem/3#4
2004 - 2012: Team 1100
2013 - ????: Team 131
