Go to Post Arefin Will You go to the prom with me :D ? i Have a dress picked out and everything :) - Tytus Gerrish [more]
Unread 14-02-2014, 21:03
antj antj is offline
FRC #4738
antj is an unknown quantity at this point
How do you use two joysticks in labview
In Labview we have initialized two joysticks one named joystick two and one named joystick 1, the problem is when we plug in joystick 2, it overrides joystick 1 and disables it. How do we make it run in tandem and not override each other?
Thank You.
Unread 14-02-2014, 22:26
Re: How do you use two joysticks in labview
Look on the Driver Station Setup tab.
On the right are listed the joysticks it sees.
You can click on each one and drag it to reorder it.
Unread 14-02-2014, 23:04
xXhunter47Xx's Avatar
xXhunter47Xx xXhunter47Xx is offline
Lord of Lazy
AKA: Austin $wagmaster1337
FRC #4738 (Patribots)
xXhunter47Xx will become famous soon enough
Oh wow...
That was so easy. I can't believe we didn't think of that before.
We appreciate all the help you've given us so far, and we also appreciate the labview examples on your team's website.
Unread 22-04-2014, 05:08
achfire achfire is offline
achfire is an unknown quantity at this point
where to find driver station setup tab plz
Unread 22-04-2014, 07:10
Launch the Driver Station. It has tabs across the top. One is labeled Setup. It is used to set team number, affect the practice match timings, and order USB joysticks.
Greg McKaskle
