Go to Post Students learn from, are inspired by, and emulate their mentors. A team with a solid mentor base helps to create a productive, inspired, and ultimately successful group of students. - Jared Russell [more]
Unread 15-02-2014, 00:29
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
Re: Odd problem with limit switch in sidecar
Cut the red wire! No, not the red wire, the blue one. Too late, I cut it.
- reference to every Hollywood movie with a bomb-defusing scene.
Most of us get so used to wiring things up with PWM cables, that we think we need to use all three wires.
Passive limit switches, like the ones in the KOP, and any that are just a set of contacts, only need two wires to operate.
One is your common, which is the black wire. No surprise there.
The other is the white wire, which goes to the signal input on the DIO input. The DIO inputs are forced ("pulled") to 5v internally to the Digital Sidecar, so that with nothing connected, or an open circuit, they read a "high" or logical 1.
To make them "low" or 0, the input needs to be brought to 0v or "common." Shorting the white and black wires through the switch contacts will do this.
There is no need for the red wire, as the input is already connected to it through a current limiting resistor inside the DS.
The only reason to use the red wire on a DIO would be if you had an active sensor that operated off of 5v, such as a photoeye or proximity switch. Most require a higher voltage for operation, though.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
