Go to Post Every year, 118 inspires our team to dream for the stars, and land on mars. If 118 wasn't there we wouldn't be off the ground. Think about it every superstar has critics. Keep doing what you do 118. - xSAWxBLADEx [more]
Unread 15-02-2014, 00:54
jdaming jdaming is offline
jdaming is on a distinguished road
Sonic Shifter Drivetrain Problem
We recently purchased the Sonic Shifter upgrade kit. We have mounted it on our kitbot and all of the pneumatic shifting seems to work fine. We have an intermittent problem with one side "sticking" a little more than the other. I know a little deviation is normal but this seems extremely excessive. The other side seems to run great. Both sides will turn and at some times it appears they are going the same speed but at other times it "sticks" and goes slower. This behavior is present in both high and low gear. Two things have me worried:
1) On the side that is affected there is a spacer that seems to be a little loose. It is still around the shaft but it can be moved unlike the other side which is solid. It doesn't seem like this would be a problem but it is the only physical difference between the two sides that I can see.
2) The side that appears to be working I can turn the wheels and when applying enough force it will turn the gears. On the other side it is quite difficult to turn the wheels by hand.
Unread 15-02-2014, 01:27
juchong's Avatar
juchong juchong is offline
Electrical Engineer
AKA: Juan Chong
FRC #2655 (Flying Platypi)
juchong is a jewel in the roughjuchong is a jewel in the roughjuchong is a jewel in the rough
Re: Sonic Shifter Drivetrain Problem
It sounds like the transmission may not have been assembled correctly. I would take it apart and make sure that it is assembled in the correct order and with the correct gears/spacers/bolts.
Teams I've worked with:My Website: http://www.juanjchong.com/
What I do: Analog Devices iSensor Product Engineer
Unread 15-02-2014, 05:13
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Out of the box we had one box that spun freely by hand and one that would not. I think they loosened and then re-tightened the plate screws to get the tighter one going. I bet you tried spinning the axle before installing at least one of yours, but maybe you didn't try both. There was also an issue with the plastic spacers for the CIM shaft. They put the pinion too far into the box so it was partly beyond the 1st stage. I overheard the muttering about AM as he used washers instead to space the pinion gear correctly.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
