Go to Post We've been thinking about just declaring our smallest kid on our BOM and making her part of the robot. - Qbot2640 [more]
Unread 15-02-2014, 01:27
juchong's Avatar
juchong juchong is offline
Electrical Engineer
AKA: Juan Chong
FRC #2655 (Flying Platypi)
juchong is a jewel in the roughjuchong is a jewel in the roughjuchong is a jewel in the rough
Re: Sonic Shifter Drivetrain Problem
It sounds like the transmission may not have been assembled correctly. I would take it apart and make sure that it is assembled in the correct order and with the correct gears/spacers/bolts.
Teams I've worked with:My Website: http://www.juanjchong.com/
What I do: Analog Devices iSensor Product Engineer
Unread 15-02-2014, 05:13
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Out of the box we had one box that spun freely by hand and one that would not. I think they loosened and then re-tightened the plate screws to get the tighter one going. I bet you tried spinning the axle before installing at least one of yours, but maybe you didn't try both. There was also an issue with the plastic spacers for the CIM shaft. They put the pinion too far into the box so it was partly beyond the 1st stage. I overheard the muttering about AM as he used washers instead to space the pinion gear correctly.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
