Go to Post the best way to make things most unfair is to have different rules for different people. - Jack Jones [more]
Unread 15-02-2014, 05:34
kmusa kmusa is offline
AKA: Karlis Musa
FRC #0639 (Code Red Robotics)
kmusa is just really nicekmusa is just really nicekmusa is just really nicekmusa is just really nice
Calibration of secondary relief valve
Because of the max working pressure of our solenoids (115 PSI), we need to have a secondary relief valve.
How does one calibrate it (besides separately), when the Norgren primary regulator won't allow the pressure to be set past 100 PSI (for the output side)?
How does this get inspected at a competition?
-Karlis
"A society without contrasting ideas will never move forward; however those contrasting ideas must be based on fact, must be rational/logical, and must be presented in a respectful manner." -Arthur Dutra IV
"If the district can spend $1.5M on turf, it should be able to fund a FRC team." -Sophie Halter
Unread 15-02-2014, 07:10
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Calibration of secondary relief valve
I would turn the norgren regulator as high as it will go (assuming that is less than 115psi. Set that secondary relief valve to that. It really doesn't matter exactly what it is. Above 70 & less than 115 psi should be fine.
Unread 15-02-2014, 08:01
matthewdenny's Avatar
matthewdenny matthewdenny is online now
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
Are you talking about the working pressure? It has to be 60 psi or less.
Unread 15-02-2014, 08:28
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
No I am talking about the secondary relief valve pressure. It has to be over 60psi & under the max working pressure of the solenoid valve. But you have to temporally turn up the working pressure to set it.
You only need it if the working pressure of the solenoid valves is <125 psi
Unread 15-02-2014, 08:32
You can also just connect it temporarily to the high side while you calibrate it.
Unread 15-02-2014, 08:40
Karlis,
This is an area of particular confusion. There is a difference between max operating pressure and recommended operating pressure. This is a case where manufacturers have maybe listened too hard to their marketing department. If the manufacture states a recommended operating pressure of 30-125 psi, that is not the max operating pressure. Your solenoids may meet FRC rules without the need for the secondary relief valve.
Unread 15-02-2014, 13:18
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
Our valves list a nominal operating pressure of 20-115 psi. Nominal as I define it mean working. They work fine at 125 PSI. Proof pressure is like 225 PSI. Since I can't find anything else written I am thinking I need the secondary relief valve
Unread 16-02-2014, 07:30
AKA: Karlis Musa
Karlis,
True. Unfortunately, the manufacturers often use operating, maximum, and/or proof pressures, and FIRST wants max working pressure (and (from Q&A) specifically excludes proof pressure as a substitute.)
In our case, STC's 4V110-1/8, with "operating pressure" of 21 to 115 PSI, and "maximum pressure" of 180 PSI (@75 Deg F).
Setting the relief valve to 100 PSI is probably the best approach (since the regulator should release anything above 60 (or whatever the current set point is.))
On the other hand, having the low pressure side at 100 PSI for the test can be a little exciting, when making sure that nothing is inadvertently activated, and the robot is disabled once the compressor cuts out. Next time, we'll just plug the output of the regulator.
Did discover some tired fittings in the process.
-Karlis
Unread 16-02-2014, 07:54
Frank and Karlis,
When I see the specification "working pressure" and it displays a range, I think that the manufacture is telling me that all operations and life cycles will be warranted under those conditions. I don't believe that the spec is a max pressure at which the valve fails to operate. This is not burst pressure. I suspect that the rule is written so that teams use components that will operate as expected should the system go over expected pressures. For instance, if a valve is holding an assembly up, I would not want the valve to suddenly bypass pressure and release the mechanism. Can you contact the manufacturer and show them the rule and how their valve is interpreted under that definition?
Unread 16-02-2014, 17:28
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
Yeah the only other thing they will give is proof pressure. I imagine liability issues and such. Anyway the secondary valve is easy & no question during inspection.
We were running the catapult latch valve on the high pressure side with no issues. (don't worry it will be where is supposed to be for competition.)
