Go to Post We don't want "The Flame Heard 'Round the World"... - Andrew Blair [more]
Unread 15-02-2014, 10:25
Doug.Pateman Doug.Pateman is offline
FRC #4618
Doug.Pateman is an unknown quantity at this point
Battery voltage will not display
SO we have our robot driving and shooting but we have a major problem. Using the KOP analogue breakout board the driver station only ever says that we have 00.00 Volts. We have tried other breakout boards and different computers as driver Stations but we just cant get it to work. Any suggestions will be helpful.
Unread 15-02-2014, 10:38
jdh042397's Avatar
jdh042397 jdh042397 is offline
Being a nerd really pays off!!
FRC #4063 (TRikzR4kiDz)
Team Role: Electrical
jdh042397 is an unknown quantity at this point
Re: Battery voltage will not display
Have you placed the jumper on the board? Normally to display the voltage on the driver station a jumper is required on the 3 pins to the left.
2014 Hub City Regional Engineering Inspiration
2012,2013,2014 Alamo Regional Gracious Professionalism
2014 Dallas Regional Gracious Professionalism
2013 Alamo Regional Winners (2468 & 2789)
2013, 2014 Hub City Regional Finalist
"Robotics are beginning to cross that line from absolutely primitive motion to motion that resembles animal or human behavior."
J. J. Abrams
Unread 15-02-2014, 10:41
FRC #4618
We tried using last year's breakout with the jumper on it as well as this year's breakout with the "built-in" jumper with no luck.
Unread 15-02-2014, 10:56
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Check this:
1 - Is the analog module in the slot closest to the cRIO power connector?
2 - Is the jumper on the breakout board installed? (it is the outer 2 pins)
3 - Is there a wire to running from analog breakout board to the PDB?
4 - Did you put a fuse in the PDB?
If it still does not work...
5 - Do any other channels on the analog module work? Perhaps the breakout module is kaput?
6 - Can you check the voltages on the breakout board? Is the "Power Good" LED on the breakout board lit up? Perhaps the breakout board is broken. It has some active circuitry on it.
Good luck!
Do you have 12v from the Power Distribution Panel wired directly to the Analog Breakout?
Is the power light on the Analog Breakout on?
Is the module in the cRIO Slot 1?
Is the module labeled "NI 9201"?
Unread 15-02-2014, 11:04
FRC #4618
Originally Posted by wireties View Post
Check this:
1 - Is the analog module in the slot closes to the cRIO power connector?
Good luck!
The module is closest to the power connector, the jumper is on the outer two pins, we do have a wire running from the breakout board to the PDB, and we do have a fuse.
The analog module works, we tested it, and we checked the voltages.
Unread 15-02-2014, 11:05
FRC #4618
We double checked everything, but it still does not work, we are clueless to why it does not work.
Unread 15-02-2014, 11:32
Can you take pictures of everything?
Unread 15-02-2014, 12:32
FRC #4618
Fixed problem. Flipped terminals on WAGO. *facepalm*
Unread 15-02-2014, 13:00
That's why we always ask to see pictures.
Unread 15-02-2014, 15:43
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
The analog breakout has reverse voltage protection - it should have survived.
Unread 15-02-2014, 20:53
yash101 yash101 is offline
AKA: null
Talking Re: Battery voltage will not display
That's one part that ain't so poorly designed as to blow up on reverse polarity
Unread 15-02-2014, 22:38
Was the power light on the Analog Breakout on with the flipped terminals?
