Go to Post I don't know how much of a safety factor chain manufacturers build into these ratings. I've got empirical evidence to demonstrate that it's not 5, however. - Tristan Lall [more]
Unread 14-02-2014, 21:15
LEDFire LEDFire is offline
FRC #4633
LEDFire is an unknown quantity at this point
Question Problem with Tank drive when activating double solenoids with Joystick Button
Hey everyone, i was recently attempting to program my joystick button in my tank drive code, and when i un-bundled the buttons to access a specific one and put it on a loop to activate if pressed. and when i went to test it, the driving code did not function at all. I don't understand how the drive code is faulty, if what i did was add a parallel operation. If anyone has any insight as to why this is happening, please share.
PS. ill add a picture of the code when time allows, so that you can see what is wrong if you don't get it from my explanation.
Unread 14-02-2014, 21:48
Re: Problem with Tank drive when activating double solenoids with Joystick Button
Teleop is already in a loop. If you added another loop inside teleop, you're now blocking other things in teleop from running. If you want a parallel loop, put your loop in periodic tasks. However, you can probably just remove the loop you added (but keep the solenoid code).
Unread 15-02-2014, 12:17
JesusC JesusC is offline
FRC #4633
JesusC is an unknown quantity at this point
Alright, ill test that out, thank you for the reply, hopefully its fixed
PS. oh and im the guy who posted, i was using a friends account when i posted
