Go to Post Hey Baker - get a haircut! :) - Sean Schuff [more]
Unread 14-02-2014, 20:37
katsauga's Avatar
katsauga katsauga is offline
Lead Programmer
AKA: Marshall Baskin
katsauga has a little shameless behaviour in the past
compressor wiring issues!
we are having a few problems with compressor wiring. With the pressure switch, I noticed that it only has a two pin cord. But the DIO slot has a 3 pin slot. Why is this??? Another thing, every time we hook up the compressor, almost all the motors stop working. I haven't been able to figure out why.
If life gives you lemons,Make grape juice and sit back and watch the world wonder how you did it
Unread 14-02-2014, 21:16
Taylor Hawkins Taylor Hawkins is offline
2386 BCHS Trojans
FRC #2386 (Trojans)
Taylor Hawkins is an unknown quantity at this point
Re: compressor wiring issues!
So the pressure switch needs to be wired to the signal and the negative post on the digital side car DIO port that your using.
As for the compressor could you give us some more information on the wiring and how it's hooked up that would help
Unread 14-02-2014, 22:25
Kevin Selavko's Avatar
Kevin Selavko Kevin Selavko is offline
AKA: Voltonless
FRC #3260 (SHARP)
Team Role: Electrical
Kevin Selavko is on a distinguished road
How are you running the compressor if you dont have the switch hooked up, doesn't the supplied compressor code and sensor default to not run the compressor?
But you may want to have your code shut off the compressor when your motors require more power.
Team SHARP
Pittsburgh Regional Champions 2014
Vex Pittsburgh Excellence Award 2014
Vex Pittsburgh Champions 2014
Vex Maryland Champions 2014
Pittsburgh Regional Finalists 2013
Buckeye Regional Finalists 2013
Unread 15-02-2014, 11:08
katsauga's Avatar
Lead Programmer
ok. I believe we have figured it out. We have gotten some help. Thanks you for all your help
Unread 15-02-2014, 12:10
cgranata cgranata is offline
Team Captain
FRC #1396 (Pyrobots)
cgranata is an unknown quantity at this point
See this thread here: http://www.chiefdelphi.com/forums/sh...hreadid=126500
I just posted some diagrams about the pressure switch and compressor wiring. Hope this helps!
Unread 15-02-2014, 12:45
katsauga's Avatar
Lead Programmer
Thanks, and do you kn ow whats really funny? jalmos is another team member of our team thanks for the help!
Unread 15-02-2014, 13:50
Team Captain
Oh ok. Haha. I saw 2 threads relating to a compressor issue and I figured I would share the diagrams with you, just in case.
Unread 18-02-2014, 11:39
katsauga's Avatar
Lead Programmer
I am still having issues. I plugged in the compressor to relay 1, but it wouldnt work. It worked when we plugged it into DI/O 1. It didn't run right though. I am not sure why it still wont work
Unread 18-02-2014, 12:05
2386 BCHS Trojans
FRC #2386 (Trojans)
Can you put up a picture of your wiring so we can take a look?
I'm not a programmer by any means but when you enable the robot does the green led next to the relay slots come on? Secondly is the pressure switch wired between the negative(-) pin and the signal (SIG) pin on the DIO? And is the Spike plugged in to the correct relay slot?
Unread 18-02-2014, 17:36
katsauga's Avatar
Lead Programmer
https://docs.google.com/file/d/0B3nK...lpUDUyOTA/edit
here is a graph of how it is set up
