Go to Post FIRST is like Starbucks coffee, it's addicting and you just can't seem to get away from it... - Beth Sweet [more]
Unread 15-02-2014, 13:23
JohnS1626's Avatar
JohnS1626 JohnS1626 is offline
FRC #1626 (Falcon Robotics)
JohnS1626 is just really niceJohnS1626 is just really niceJohnS1626 is just really niceJohnS1626 is just really niceJohnS1626 is just really nice
cRio Reboot?
We are trying to format our cRio and it is stuck on reboot. We're not entirely sure how to fix it, but for now we can't find a way to stop rebooting safely. Does anyone know how we can exit the formatting tool while it is rebooting? The close button isn't usable.
We are using labview and our ethernet cable is plugged directly into the cRio.
Thanks for the help!
Unread 15-02-2014, 13:42
peter1626 peter1626 is offline
peter1626 is an unknown quantity at this point
Re: cRio Reboot?
Check out this thread:
http://www.chiefdelphi.com/forums/sh...c trio+device
or this one http://www.chiefdelphi.com/forums/sh...c trio+device and finally this one: http://www.chiefdelphi.com/forums/sh...k+on+Rebooting
They all have a bunch of suggestions!
2010 SBPLI Long Island-Regional-Imagery Award in honor of Jack Kamen
2011 New York City Regional-Industrial Design sponsored by General Motors
2011 SBPLI Long Island Regional-Regional Winner
Unread 15-02-2014, 16:35
om_nom_nom om_nom_nom is offline
AKA: Nam
FRC #0708 (Hardwired Fusion)
om_nom_nom is an unknown quantity at this point
Re: cRio Reboot?
From my experience, you have to be connected to Wi-Fi for it to successfully reimage. So I guess check to see if you have internet connection first, and see if that solves your problem.
Unread 15-02-2014, 20:06
Re: cRio Reboot?
Use the Windows Task Manger to end the Imaging Tool process. Then it would be a good idea to restart Windows, because things might not be completely stable afterward.
I've had "stuck on waiting for reboot" issues a few times this year. Every time, I found an extra IP address had been added to the wired network adapter (probably by the Bridge Configuration Utility). Going into the IPv4 properties' "Advanced" settings and removing the extra address has always made it work for me.
It's is generally discouraged to try to format a cRIO over a wireless connection. The usual advice is to disable every adapter other than the single wired one that should be connected to the D-Link router, with the cRIO also connected to the router.
Unread 15-02-2014, 21:06
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: cRio Reboot?
Using a crossover cable can be effective as well.
Unread 15-02-2014, 19:51
Breakaway3937's Avatar
Breakaway3937 Breakaway3937 is offline
Director
AKA: Brian "Robo" Jones
FRC #3937 (Breakaway)
Breakaway3937 is just really niceBreakaway3937 is just really niceBreakaway3937 is just really niceBreakaway3937 is just really niceBreakaway3937 is just really nice
Re: cRio Reboot?
From what it sounds like, we had the same issue. We hit the reset button on the cRio. It then rebooted in safe mode. We set our IP Address to automatically detect. Went to the reimaging tool, and reset it to factory settings, then reimaged it again with the correct updates. I would definitely do this tethered.
Hope this helps.
"There is no luck. It is only when preparation meets opportunity."
