Go to Post We are making this up as we go along - please don't confuse us by telling us the way that it really should be done. - dlavery [more]
Unread 14-02-2014, 23:13
xTezzie's Avatar
xTezzie xTezzie is offline
FRC #4940
xTezzie is an unknown quantity at this point
Autonomous backup solution?
So my teammates and I had written a code and messed up the cardinal rule of programming (always back your code up!). We were wondering if there was a way to retrieve it, or if we were just screwed and need to rewrite it, which is something we would like to avoid doing because we did it with a mentor and don't recall all of the important syntax surrounding it.
If we cannot recover it, (sad face) could someone give us some pointers in using autonomous to code..
Method 1: Jaguar backwards
Method 2: jaguar stopped
Method 3: upper and lower wheels sucking in
Method 4: upper and lower wheels stopped
Method 5: jaguar up
Method 6: jaguar stopped
Method 7: upper and lower wheels shooting outwards
Method 8: upper and lower stopped
Method 9: chassis drive forward
Obviously some of these can be at the same time.
Let us know!
Team 4940
Unread 15-02-2014, 14:14
1024Programming 1024Programming is offline
FRC #1024
1024Programming is an unknown quantity at this point
Re: Autonomous backup solution?
In CommandBase autonomous is pretty simple if you use command groups. You basically just write a list of the commands you'd like to use in the order you want to use them.
The two commands you use are:
addSequential(new Command(), timeout)
addParallel(new Command(), time out)
They each run the command for the amount of time
For Example:
addSequential(new JagsBackwards(),2);
addSequential(new JagsStop(),0);
addParallel(new UpperJagsIn(),2);
addParallel(new LowerJagsIn(),2);
etc...
Unread 02-03-2014, 20:55
ProgrammerMatt ProgrammerMatt is offline
Programmer-Electrical-Mechanical
FRC #0228 (Gus)
ProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really nice
Method 5: jaguar up
Let us know!
Team 4940
You should use GitHub. Netbeans supports it nativally and you can commit changes then if you mess up revert to a working copy, it even highlights code changes!
2015-2016 CSA
Software Engineering Student @ Johnson & Wales University
Team 228, Gus Robotics Inc.
Facebook
FLL Mentor for 1107, Edison Eagles!
2015- CT State Champions
2012- WPI Finalist(Thanks 1884 and 549), Spirt, Best Website
2011- WPI Chairman's award winners!
2010- WPI Champions! (thanks 230 & 20), WPI Engineering Inspiration, CT Best Website, CT VEX Champions (VRC228, VRC228b) (21-1-0)
2009- QCC VEX Champions (VRC228) (11-0-0), Innovate Award (VRC228)
