Go to Post Oh, you know us...kicking puppies and stealing candy from babies and all. :rolleyes: - Travis Hoffman [more]
Unread 14-02-2014, 23:38
zackd97 zackd97 is offline
FRC #4102
zackd97 is an unknown quantity at this point
Mecanum wheel twist issues.
This year we are working with a mecanum drive system. We have everything working peachy but the twist. When we twist the joystick, the robot moves in a completely random pattern. Forward, backward, and strafe are all fine.
To handle the operations we are using the Cartesian mecanum drive. For the twist we tried using
stick.GetTwist()
and
stick.GetZ()
Using the GetTwist caused the robot to spaz out upon enabling. Using the GetZ seemed to be working but when twisting the robot acted like it was fighting against itself. At first I thought it may be interference from other joystick values, but I also called the mecanum Cartesian drive with no input besides a 1 for twist, which caused the same spastic behavior as using GetTwist.
Do you guys have any idea what the problem may be? At this point, we think it may be a mechanical issue.
Unread 15-02-2014, 09:29
Re: Mecanum wheel twist issues.
stick.GetTwist()
and
stick.GetZ()
Gently tip the bot up on its side and take a picture of the bottom showing all 4 wheels and post it here.
Then put the bot on blocks (all 4 wheels off the floor) and give it a twist (rotate) command, tell us what direction each of the wheels is spinning.
What model joystick are you using?
Unread 15-02-2014, 14:48
FRC #4102
Here is a picture of the underside of the bot:
Please excuse the sub par wiring job. We're still working on cleaning that up.
When twisting the joystick to the left, the front and back wheels turn away from each other. The front go forward and the back go backward. When twisting the joystick right, that is reversed, with the front going back and the back going forward.
As for the joystick, we are using a Logitech extreme 3D pro.
Unread 15-02-2014, 15:37
All four wheels appear to be mounted in the correct configuration.
That would explain why you are not rotating.
To rotate clockwise, the left wheels should be going forward and the right wheels backward. Vice-versa for turning counter-clockwise.
Unread 15-02-2014, 16:57
FRC #4102
So could this possibly be an issue with the ports the motor controllers are plugged into?
Unread 15-02-2014, 17:03
Halo_Kid_3633's Avatar
Halo_Kid_3633 Halo_Kid_3633 is offline
FRC #3633 (Catayst)
Halo_Kid_3633 is an unknown quantity at this point
A sample code maybe helpful.
haha
- Yup Me
Unread 15-02-2014, 17:09
At this point, I would say it appears to be either a wiring error or a code error. I bet if you post your code and focused pictures of how you have the motors wired you'll get more detailed help.
Unread 15-02-2014, 18:11
FRC #4102
Right now the only portion of code that has anything to do with the driving looks like this:
myRobot.MecanumDrive_Cartesian(stick.GetX(), stick.GetY(), stick.GetZ());
stick being the joystick and myRobot being the robot drive.
The ports are initialized as so:
myRobot(1,2,3,4),
stick(1)
The wiring is as follows:
Front left motor- Port 1
Front right motor- Port 2
Back left motor- Port 3
Back right motor- Port 4
EDIT:
I forgot as a side note, the MecanumDrive_Cartesian calls for input from a gyro at the end. That has not been included yet as we are working on getting our gyro mounted and working now.
Unread 15-02-2014, 21:24
The RobotDrive constructor takes four motors in the order frontLeft, rearLeft, frontRight, rearRight. It looks like you have ports 2 and 3 swapped.
Unread 16-02-2014, 21:04
FRC #4102
This was the solution. Thank you!
