Go to Post Teams whose goal is to play on Einstein think about strategy differently from teams whose goal is to be selected for an alliance at a district event. - alopex_rex [more]
Unread 15-02-2014, 14:52
jSoft jSoft is offline
GG Hirez
AKA: J.R.
FRC #4918 (The Roboctopi)
jSoft is on a distinguished road
Aborting a Flat Sequence
Hi everyone, I'm J.R., the programmer from rookie team 4918. I wanted to know if it's possible to abort a flat sequence mid-execution in labview. Thanks for the help!
Unread 15-02-2014, 15:04
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Re: Aborting a Flat Sequence
No, there is generally not a good way to stop a structure mid-execution. If you find the the pressing need to do this, it may be better to implement your code as a state machine instead. This way, you can manually change the states yourself.
Unread 15-02-2014, 21:50
Aborting or jumping out of structures in procedural languages is convenient, but tends to cause bugs caused by uninitialized variables. In a data flow language, that is even less of a good idea. So the structures are required to identify a value for all ways to exit. The exit is generally quite controlled., no break or continue statements except. The solution is to make the downstream code be conditional.
Greg McKaskle
