Go to Post This is where a tenacious NEM comes in very handy. - Mark McLeod [more]
Unread 15-02-2014, 16:43
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
Timeout exceeded in RobotDrive?
Hey guys, this errors been bugging us. It always constantly appears on the netconsole, no matter what we do, over and over again. Does anyone know what it means?
>>>>ERROR: A timeout has been exceeded: RobotDrive... Output not updated often enough. ...in Check() in C:/WindRiver/workspace/WPILib/MotorSafetyHelper.cpp at line 117
Thanks!
EDIT: we figured out the error. We use our own arcadedrive so that we can add modifiers, because an issue in the past has been one side runs slower than the other. However, I wasn't sure what SetSafetyEnabled and SetExpiration are in the RobotDrive class, so we instantiated a myRobot with bogus port numbers, just so we can do those functions. However, when we comment them out the errors disappear.
So my new question is thus: Are setsafetyenabled and SetExpiration required functions? If we don't instantiate a robotDrive at all, will that be an issue with the fms? I've been treating this robotDrive as black-box code, so if this question seems a bit silly, thats why xD
"Measure with a micrometer, mark with chalk, cut with an axe."
Last edited by Sparkyshires : 15-02-2014 at 19:49. Reason: solved old issue, new issue arose
Unread 15-02-2014, 19:50
Re: Timeout exceeded in RobotDrive?
It means you have defined some robot drive motors, and you failed to set their values at least every 100 milliseconds. Look in Teleop to make sure something isn't blocking execution for a long time.
