Go to Post *When putting grease on anything* "The bigger the glob the better the job." - TheMagicPenguin [more]
Unread 08-02-2014, 18:38
forbes's Avatar
forbes forbes is offline
Software developer
AKA: Evan Forbes
FRC #3507 (Ubotics), 694 (StuyPulse)
forbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to behold
Can't deploy code: Waiting for the target (RT CompactRIO) to respond
We are connected directly from the programming computer to the crio. The computer's IP is set to 10.35.7.5. The firewall is off. We just reformatted it earlier today.
We also occasionally get an error that says "access denied another project is using this target".
Any help would be appreciated, let me know if you need more information.
Unread 08-02-2014, 19:24
chigskonkwo chigskonkwo is offline
FRC #0884 (Mechanical Mules)
chigskonkwo can only hope to improve
Re: Can't deploy code: Waiting for the target (RT CompactRIO) to respond
I believe you should Re-Image your cRIO, then try to deploy code again.
Unread 08-02-2014, 19:36
forbes's Avatar
Software developer
AKA: Evan Forbes
Sorry, that's what I meant by reformatted in the original post. We reimaged it when it did this to us earlier, it worked for a couple deploys then stops deploying, giving the waiting for target error.
Unread 08-02-2014, 20:24
The "access denied another project is using this target"
happens when one of your debug sessions gets interrupted and
LabVIEW thinks a session is still running when it isn't.
When this happens go to the Project Window,
Right-click on RT CompactRIO Target,
Select Disconnect
You can reset the cRIO too if you like.
The waiting for target to respond error is usually the computer's fault rather than the cRIO.
Something in the IP address/netmask, multiple active NICs, virus checkers/firewall settings disturbs the network connection.
Unread 14-02-2014, 20:03
gswizzle gswizzle is offline
FRC #4265
gswizzle is an unknown quantity at this point
Most of the time if you just turn the robot off and then on again it'll connect fine.
Unread 15-02-2014, 16:54
Joe Hershberger Joe Hershberger is offline
National Instruments
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
It can also be caused by the cRIO being too busy with the robot program to respond the the commands to deploy new code. On work around for this is to use the imaging tool to set the No App switch, apply settings, deploy your new code, unset the No App switch, apply settings.
