Go to Post Am I the only one who thinks robots are the main attraction of a regional, and there isn't a need for more distraction? - Adam Richards [more]
Unread 15-02-2014, 20:10
randalcr's Avatar
randalcr randalcr is offline
Programming Mentor
AKA: Chance Randall
FRC #0476 (Wildcats)
randalcr is an unknown quantity at this point
Re: Driver won't communicate with robot
check to see if there are any wifi networks that could be interfering with your signal, if there is, change it to something that isnt being used. If that doesn't work, check the diag tab of the driverstation and see if you are getting watchdog errors, if you are then look at your code and see if there are any functions that are taking a ton of cpu and slowing down the rest of the program.
if all else fails, reconfigure the bridge and the router from defaults .
-Time is the best teacher...unfortunately it kills all of its students. --Robin Williams
Unread 15-02-2014, 20:17
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
How is you radio wired?
Be sure it is wired according to this diagram.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 16-02-2014, 18:03
You may also want to see if other computers are using the same IP address. You would normally see a nice message telling you such, but this weekend at a scrimmage, I saw it simply act squirrelly and drop the connection. Of course the router would also lose power because the battery was low and radio wasn't boosted, so it was hard to tell what was causing what.
Greg McKaskle
Unread 17-02-2014, 11:40
Potatonator's Avatar
Potatonator Potatonator is offline
much potato very robot wow
FRC #4360 (Spudnik)
Potatonator is an unknown quantity at this point
Thanks for the suggestions--we have triple-checked the radio wiring, no luck. There are also no other computers with the IP address we are using.
We get many dropped packets (typically ~25) and repeated warning messages in the diagnostics:
Warning 44004 Error on Driver Station [paraphrased, but the error code is right]
Warning 44002
and the status of the connection to the robot keeps changing from good to bad and back.
We do not have that problem when using the wired connection.
We are trying to connect wirelessly, but the complete network settings on the classmate are:
wired connection:
IP: 10.43.60.5
subnet mask: 255.0.0.0
wireless connection:
IP: 10.43.60.9
Unread 17-02-2014, 11:45
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
This would initially appear to be one of three cases:
Network congestion. Are your robot and driverstation the ONLY two computers on the network?
Wifi congestion. Are there other networks in close proximity that utilize the same channel that might be interfering?
Gaming adapter placement. Is your adapter away from the drive motors, battery cable, and also not surrounded by metal?
Also, you should check the CPU usage of the cRIO. You can check it from the driver station. If it is at 100%, your code is likely the culprit.
Do the symptoms disappear when you tether? Do they happen when your robot is stationary, or only when it is trying to move (under electrical load)?
Unread 17-02-2014, 12:06
Have you accidentally started the Driver Station program under two users simultaneously?
Unread 17-02-2014, 13:24
FRC #4360 (Spudnik)
Yes
We aren't sure how to check on that
Yes
CPU usage is just fine
Problems go away when we tether, but they do happen even if it's not moving.
@Alan: We checked, we aren't running it twice.
We're thinking it might be a bad router, but not sure yet.
Unread 17-02-2014, 16:47
icecube45's Avatar
icecube45 icecube45 is offline
Drive|Programming|Captain
FRC #0114 (Eaglestrike)
Team Role: Driver
icecube45 is a jewel in the roughicecube45 is a jewel in the roughicecube45 is a jewel in the roughicecube45 is a jewel in the rough
Potatonator,
We had the same problem, and unfortunately lost about 3 days of build time trying to solve it.
I believe it is simply wifi congestion for you,
at our workspace (school), we get the same error, but at nasa yesterday for driver practice (thanks 254), we had no problem, as there were only two wifi networks there, compared to the ~10 here.
If you can, try to go somewhere with less wifi, and check if you still have the problem.
We're kind of stuck with driver practice until we can find a spot at the school to practice (put your robot on the cart, and go travel around to different areas, looking for a less congested space)
Hope you resolve this,
icecube45
Unread 17-02-2014, 17:12
FRC #4360 (Spudnik)
I just checked the wifi channels at our school. As far as I can tell, our router is channel 1, and all the school's networks are 11. So I doubt interference is the issue.
Unread 17-02-2014, 17:26
Chris_Ely's Avatar
AKA: luckof13
I have seen this happen at demos when there are many WiFi networks , and devices around. Other devices like smart phones will try to connect automatically to the network. We solved this problem by making the robot network an encrypted hidden network by selecting enable hidden wireless in the radio's wireless settings.
Unread 17-02-2014, 17:55
FRC #4360 (Spudnik)
How would we access the radio's settings? We can't seem to find it.
Unread 17-02-2014, 18:00
Chris_Ely's Avatar
AKA: luckof13
Go to the radio's IP address in a browser. Then go to setup, and check "Enable Hidden Wireless," and hit save. You will then have to manually tell your computer to connect to the network as described here.
Unread 17-02-2014, 18:15
samfruth's Avatar
samfruth samfruth is offline
FRC #1710 (Ravonics Revolution)
Team Role: Driver
samfruth will become famous soon enough
The only other solution I can think of is that in Driver Station under the Setup tab in the 'Choose NIC' option make sure that your setting is set so that you DON'T configure it automatically, but instead through wifi. However, I believe that you said you were able to connect, so this may not be a viable solution.
