Go to Post Maybe this thread should be re-titled "Waiting impatiently for the 2011 hint!" since having over 100 posts doesn't seem very patient. - Joe Ross [more]
Unread 15-02-2014, 12:44
katsauga's Avatar
katsauga katsauga is offline
Lead Programmer
AKA: Marshall Baskin
katsauga has a little shameless behaviour in the past
Question FESTO pneumatic switch
Our team is having trouble with the festo pneumatic switch. We have already plugged it into slot 1 & 2 on the cRIO, like shown in a diagram we got. I have checked, my code, and rechecked it. I am not sure where our error is, any help? I am so confused
If life gives you lemons,Make grape juice and sit back and watch the world wonder how you did it
Unread 15-02-2014, 13:08
DonRotolo's Avatar
Back to humble
FRC #0832
Re: FESTO pneumatic switch
Maybe some details on your code and the connections would help us help you
Unread 15-02-2014, 13:17
katsauga's Avatar
Lead Programmer
in begin. vi :
I have the it set to relay 1 channel and D I/O 1 channel connected to a Compressor open. The comp. open lead to a comp. set, which named the compressor "com". That leads to a compressor start.
in finish.vi:
Outside the shell, I have a compressor get connected (by refnum name "com").
Inside the shell, I have a compressor close connected back to the compressor get
Unread 15-02-2014, 19:36
What are you expecting to happen? What is happening instead?
Unread 15-02-2014, 20:11
yash101 yash101 is offline
AKA: null
We were also having problems with the FESTO valves! We went to a prebag competition and our robot was unable to do anything but drive because the FESTOs just wouldn't work!
Unread 15-02-2014, 22:56
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Are the lights on your solenoid breakout lighting up when you attempt to actuate the solenoid? If they aren't it is most likely a code issue. If they are check your voltage supplied to the breakout. 12v solenoids need 12v and 24v need 24v or they won't work very well.
We had the same issue earlier in the season until we noticed that we forgot to supply power to the breakout board.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 15-02-2014, 23:12
tgross35 tgross35 is offline
FRC #4810 (I Am Robot)
Team Role: Electrical
tgross35 is an unknown quantity at this point
Like some people have mentioned, make sure that your breakout has power (so the LED on it should be on.) Then make sure that your breakout is on the right module (the solenoid module must be in the third slot of the cRIO. It's the module with 6ish green LEDs on it, if you need to the number should be easy enough to find.) Then try flipping your connector, it's an easy mistake to make (especially since the diagram is labelled in the side while the pins are on the top.) Hope you solve your problem!
