Go to Post We're moving to metric, inch by inch. - Joe Ross [more]
Unread 10-01-2002, 20:35
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Ouch that ruling hurts...
> Is it legal to DRAG an opposing alliance robot against its will
into your home zone for an additional 10 points?
A) Yes, becareful that the mechanism you are using to attach (or
drag) a robot can be easily released. Also remember that the 1
minute setup and resetting period will apply, see rule GM6.
Will this violate "PINNING" rules?
A) No. Pinning refers to holding a robot against the edge of the
field or against the side of the goal. See Team Update #1 for rule
DQ8.
What happens if you damage their robot while dragging them?
A) If the referees determine it was caused by malicious behavior, the
alliance causing the damage will be disqualified. If the referees
determine that the damage was due to "poor Robot design", then there
will be no penalty. In all cases, it will be a referee judgement
call.
Is is just me or does this new rule scare the bejebbers out of the rest of you too?
I am not sure if I should be designing THE CLAW or working on some other aspects of the game.
Time will tell.
Joe J.
Unread 10-01-2002, 23:23
Jon Abad's Avatar
Jon Abad Jon Abad is offline
Boston Regional Planning Committee
Team Role: Communications
Jon Abad will become famous soon enoughJon Abad will become famous soon enough
Send a message via AIM to Jon Abad
i was pretty worried at that too. we thought about it in brainstorming but since there isn't a standard "towing hitch" then we don't want to take the risk of hurting anyone.
(So keep your mitts off Gompei 2002!)
Jon Abad
-Boston Regional Planning Committee
Unread 10-01-2002, 23:33
Suneet Suneet is offline
Physicist-In-Training
None #0599 (RoboDox)
Suneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to behold
Send a message via ICQ to Suneet Send a message via AIM to Suneet
If a team tries to use THE CLAW, there will surely be ways to escape it. Eventually, teams will know their strategy and find ways to avoid them, and the team can waste its time chasing after a moving 10 points with a drive system and intelligent controllers when they could be doing something more point worthy.
~Suneet who will be shocked when ChiefDelphi drags his robot to their side if he sees them at Nationals
Unread 11-01-2002, 03:35
joe_balint joe_balint is offline
FRC #3324 (Metrobots)
joe_balint is an unknown quantity at this point
I like it. We should definitely see some robust wiring schemes and streamilined, groud-hugging chassis coming out of the controls and Chassis CDTs respectively. If not, that will be cool too! -Joe note: CDT=Component Design Team
Engineer
joe.balint@gmail.com
http://www.OhioValleyTesting.com/
"The greatest enemy of a good plan is the dream of a perfect plan." -Clausewitz 1832
Unread 11-01-2002, 09:24
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
Have you not seen in the past what robots have done. it has always come down to one robot hitting others to stop them from doing what they would like to do.
so chasing after another robot is going to be a big factor in the finals.
just think if you are lifted off the ground can your robot fight back.
and if it does fight back will you be able to right yourself if fliped over.
just think of the points. both team robots are off the ground with no control the other team can place the points any where they need to get the most point.
Unread 12-01-2002, 19:17
Eddie Eddie is offline
#0620 (Chimera)
Eddie is an unknown quantity at this point
Send a message via AIM to Eddie
this is not Battlebots
That is a good point; controlling the field is very advantageous. But remember that maximizing both teams scores will get you the most points, as long as you still win. If you focus on flipping other robots over, dragging them, or trapping them somehow, then you can do nothing but garauntee a win for your team. If you can garauntee a victory and still make sure that the opposing team has lots of points, then you will be much more successful.
Just some thoughts...
Unread 12-01-2002, 19:23
FRC #0061
Rookie Year: 1995
This is good only for the seeding round.
Unread 13-01-2002, 15:42
Warren Boudreau Warren Boudreau is offline
FRC #0180 (Team SPAM)
Warren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond repute
Joe,
I'm with you. That ruling is opeing the door for disaster. Pushing a robot against it's will is a whole lot different that grabbing and dragging.
The entire ruling goes contrary to the gracious professionalism that we are supposed to be demonstrating to the students.
Warren B
Pool Noodles. They're not just for bumpers anymore.
Unread 13-01-2002, 22:47
Tom Fairchild's Avatar
Tom Fairchild Tom Fairchild is offline
Nice Guy
Tom Fairchild will become famous soon enoughTom Fairchild will become famous soon enough
Send a message via AIM to Tom Fairchild
I wouldn't sweat this one too much. Personally I don't think that many teams are going to spend time trying to build a robot that can/will pick up another robot. If anything, the physics of it would be difficult. 130 lbs that you're picking up vs. the 130 lbs that you weigh means that more than likely you'll tip over your wheels (yes, many ways around this, but will teams bother trying?) There are many other ways to score points that are easier than this.
~Tom Fairchild~, who thinks that its going to be like teams lowering their own score two years back - a problem that could have arised but never really did.
Unread 14-01-2002, 07:19
AKA: Dr. Joe
FRC #0088 (TJ2)
It is easier than you think...
I won't give folks ideas, but let me just say that it would be easier than you might think to build a robot hauler.
I don't want to build one, but if I did, it would not have to worry about falling over as you describe.
Here's to robot haulers being rare and unsuccessful!
Joe J.
Unread 14-01-2002, 10:20
kevinw kevinw is offline
kevinw is a name known to allkevinw is a name known to allkevinw is a name known to allkevinw is a name known to allkevinw is a name known to allkevinw is a name known to all
Haul Away
I think robot haulers might actually add an extremely interesting dimension to the game. Just like the Naval Undersea Warfare Specialists robot in '97 which flipped the 2 opposing robots before scoring, it will be exciting to watch.
Here's to robot haulers that don't damage opponents' robots!
Unread 15-01-2002, 15:43
Anton Abaya's Avatar
Anton Abaya Anton Abaya is offline
None #0419 (Rambots)
Anton Abaya has a spectacular aura aboutAnton Abaya has a spectacular aura aboutAnton Abaya has a spectacular aura about
Send a message via ICQ to Anton Abaya Send a message via AIM to Anton Abaya
if i made my robot to push other robots at a height of 4ft or higher.... and robots end up tipping over, is this regarded as tipping another robot?
is it my fault that bot isnt robust enough to not tip over?
-anton
Unread 16-01-2002, 23:15
Mike Rush's Avatar
Mike Rush Mike Rush is offline
Somewhat Insightful
FRC #4154 (Perpetual Recursion)
Mike Rush is just really niceMike Rush is just really niceMike Rush is just really niceMike Rush is just really niceMike Rush is just really nice
Make your self hard to grab... Otherwise someone is going to try to do it to you... Yikes..
Unread 17-01-2002, 19:36
Dindau Dindau is offline
#0365 (Miracle Workerz)
Dindau is an unknown quantity at this point
Smile Moving Wedge
I agree with mike.
But also dont take it to the extreme, in which you make a moving wedge which cant do any other function but move.
Unread 18-01-2002, 19:33
Hubicki Hubicki is offline
#0007 (Team Firestorm)
Hubicki is an unknown quantity at this point
In response to Anton, it depends on the situation (and what the referee calls). I you're robot makes an obvious attempt to tip the other robot (ramming it and continue pushing when it's off balance or deploying a wedge that upends it, etc.), then it your alliance will be disqualified (which is really bad because the other alliance gets triple their own score!). However, DQ3 clearly states that accidental tipping of robots will be allowed at the discretion of the referees. So if you accidentally bump a robot with a high CG and it tips, you'll probably be fine. Of course, you should be careful with 'accidental ' tipping because you never know what the referees will call. Hope I helped you out.
~Hubicki~
Ruling Consistancy in Houston Rick Rules/Strategy 22 16-04-2003 00:28
Light ruling. From FIRST Gadget470 General Forum 2 17-02-2003 18:46
$3500 ruling......big mistake JamesJones Rules/Strategy 42 13-01-2003 18:38
Did You See this Ruling? Paul Copioli Rules/Strategy 9 17-02-2002 02:06
New ruling from FIRST re: repair parts Mike Martus Rules/Strategy 0 31-01-2002 21:40
