Go to Post Don't fight success. - Al Skierkiewicz [more]
Unread 15-02-2014, 21:24
Re: Mecanum wheel twist issues.
Originally Posted by zackd97 View Post
The wiring is as follows:
Front left motor- Port 1
Front right motor- Port 2
Back left motor- Port 3
Back right motor- Port 4
The RobotDrive constructor takes four motors in the order frontLeft, rearLeft, frontRight, rearRight. It looks like you have ports 2 and 3 swapped.
Unread 16-02-2014, 21:04
zackd97 zackd97 is offline
FRC #4102
zackd97 is an unknown quantity at this point
This was the solution. Thank you!
