Go to Post The best revenge is living well. - gblake [more]
Unread 15-02-2014, 10:45
CarrotBlasphemy's Avatar
CarrotBlasphemy CarrotBlasphemy is offline
FRC #4226
CarrotBlasphemy is an unknown quantity at this point
Vision code hangs cRIO
I'm using the basic sample code for detecting a hot goal and when I run it, it keeps printing out "Robot drive... Output not updated often enough" Is there a way to fix this to run the vision code but not hang? Also, in case this matters, I'm calling it from a separate class
Unread 15-02-2014, 10:49
mechanical_robot's Avatar
mechanical_robot mechanical_robot is offline
Team Role: Driver
mechanical_robot will become famous soon enough
Re: Vision code hangs cRIO
May I ask how did you get the hot target example code working? I'm still trying to figure out how to get vision code to work.
Unread 15-02-2014, 10:54
FRC #4226
I didn't do much, but so far I've only used the test images. But actually, I'm pretty sure I had to add something in there that printed out target.Hot. So I'm not sure why it's missed that section but I added it in and it seems to work
Unread 15-02-2014, 22:34
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Do you a wait statement in your vision loop of perhaps 100 or 150 ms so that it allows your other code to get a shot at the cRIO's processor? If not, then the cRIO is running the vision code as fast as it can, your cpu is at 100% utilization, and your other code isn't having a chance to run in a timely manner.
Unread 16-02-2014, 13:53
Randaline's Avatar
Randaline Randaline is offline
AKA: Abby
FRC #0716 (The Who'sCTEKS)
Randaline is an unknown quantity at this point
You're not alone our team's been using the example vision code and have gotten it working, but it takes five seconds or longer, no matter what we change. It's a problem considering the hot goals change within 5 seconds...
Unread 16-02-2014, 14:49
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
We were running into the same problem, but think we've got it working. What language and camera are you using? We're using the m1011 and C++ and what we found is that you have to initialize the camera outside of the autonomous loop, else the camera won't begin the startup sequence until you enable autonomous. If you place
static AxisCamera *camera;
right after the #define's, and delete the other declaration thats right inside the autonomous loop, that should help a bit.
Also, to OP: try decreasing the fps. We found that 4 or 5 fps is more than enough, but it tries to default to something crazy like 30.
"Measure with a micrometer, mark with chalk, cut with an axe."
Unread 16-02-2014, 14:51
AKA: Michael Shires
FRC #0384 (Sparky)
CarrotBlasphemy - that has to do with your robotDrive instance is not getting motor values. Make sure that everywhere in the code, you're sending drive values. Or if your using custom drive code, then that would also throw an issue.
Unread 16-02-2014, 17:33
Tom Line's Avatar
It would also help if we knew what language you were using.
Unread 16-02-2014, 17:38
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
We found this too. We were using iterative robot. We did two things to make this easier on the crio. The first is to only call vision calls every n loops (we use 10). The second is not to use the area filter but rather a particle width filter:
cc.addCriteria(NIVision.MeasurementType.IMAQ_MT_BO UNDING_RECT_WIDTH, 8, 65535, false);
We were 100% at week zero at detecting hot correctly.
