Go to Post Courtesy and kindness should be the words for the weekend. - IndySam [more]
Unread 15-02-2014, 19:34
LFRobotics's Avatar
LFRobotics LFRobotics is offline
FRC #4623
LFRobotics is on a distinguished road
Motor Speed Values
What is the max speed value I can give a motor?
Like is
motor.set(10);
any faster than
motor.set(1);
THANKS!
Unread 15-02-2014, 19:41
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
No. The motor values go from -1 to 1. Giving it a value of 10 is either going I cause an error or be the same as 1.
Unread 15-02-2014, 19:57
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Re: Motor Speed Values
The set method calls the setSpeed method of the PWM class.
If you look at the source code of this class, you can see that any input is constrained to be between 1.0 to -1.0.
final void setSpeed(double speed) {
            // clamp speed to be in the range 1.0 >= speed >= -1.0
            if (speed < -1.0) {
                speed = -1.0;
            } else if (speed > 1.0) {
                speed = 1.0;
1.0 and -1.0 don't directly correlate to an actual motor speed. They will just dump 100% battery voltage to the motor in the specified direction. The speed the motor will travel at under this condition is dependent on a number of factors like gearing, load, battery voltage, etc.
http://team2168.org
Unread 15-02-2014, 22:56
LFRobotics's Avatar
FRC #4623
Okay - THANKS!
