Go to Post ...It's two years old, but GP is GP. - Brandon Martus [more]
Unread 19-01-2014, 13:17
Rstrzelecki Rstrzelecki is offline
FRC #0135 (The Black Knights)
Rstrzelecki is an unknown quantity at this point
Solenoids for shifting gearboxes
My team is using WCP 2-speed transmissions with pancake cylinders. We are having trouble deciding which solenoids to use. Could someone share what their team has used or knows to work well?
Unread 16-02-2014, 00:00
tgross35 tgross35 is offline
FRC #4810 (I Am Robot)
Team Role: Electrical
tgross35 is an unknown quantity at this point
Re: Solenoids for shifting gearboxes
My team always gets the CKD solenoids from AndyMark, and we haven't had any issues. Remember to get 3 M5 Pisco fittings (sold from AndyMark too) and tighten these using an allen key inside (it's tapeless but you need to tighten it from inside the fitting.) I recommend a single-acting solenoid for this use, so it will return automatically to a certain direction if your robot loses a signal or the wire tears loose for some reason. Hope it helps!
Unread 16-02-2014, 02:42
AlecS AlecS is offline
FRC #1323 (Madtown Robotics)
AlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond repute
Rstrzelecki,
VEXpro sells compact SMC SY-series valves and manifolds. These are very useful if you have more than 1 valves, as the manifold saves significant space over multiple body ported valves. The 1/4" tubing fittings built into manifold will interface directly with the standard 1/4" FRC tubing.
Alec S.
Engineer - Sales Representative, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 16-02-2014, 02:55
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Originally Posted by AlecS View Post
Rstrzelecki,
Have to say, we got them for our comp and practice bots this year, and we just love them. They're super useful, real small, and we never have to worry about mounting solenoids anymore.
-Plutarch
