Go to Post So.... football pizza water game with minibots and megabots? - euhlmann [more]
Unread 16-02-2014, 10:24
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Enhanced I/O in 2015?
Hi beta testers!
Do you know if there will be an EnhancedIO in the 2015 control system? We've typically been using the Cypress board for digital outs, i.e., status LEDs on our IO controls box. Unfortunately the Cypress board has been discontinued, so I know that that solution isn't viable moving forward.
Yes, I know that there is the smartdashboard (when you can get it to work), but that appears on the driver's console screen and is difficult for the co-driver to see. Additionally, the driver is typically so focused on the 'bot that they don't look down at the screen at all. So, a nice, big, bright LED that turns on then the 'bot is ready to shoot is a real attention getter.
I suppose that it would be ideal if National extended the LabView Arduino interface so we could access all of the I/O pins on an Arduino mega. But, I'm just checking to see if anyone knows the answer.
Thanks,
Mike
Unread 16-02-2014, 10:31
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Re: Enhanced I/O in 2015?
Why not put that nice bright LED on the robot, there are plenty of IOs on the controller for that, and driver never has to take his eye off the bot.
Former Mentor Team 1771
Former mentor Team 4509
Unread 16-02-2014, 11:09
Software Mentor
AKA: Mike Anderson
If it were just one LED, we could certainly do that. But, there are a number of such LEDs for different subsystems (e.g., ball ready to shoot, within range for a shot, ball jammed, etc.). Not specifically things the driver (i.e., mobility jockey) is concerned about. The Co-Driver (i.e., Button-B*tch) is working to take the situational-awareness load off of the driver along the lines of the F-15E /A-6 pilot vs. weapons officer. I'm just checking on the Enhanced I/O because of the digital outs. Joysticks/game controllers just don't have the feedbacck that makes interaction on the field as easy to work with.
Here's an example from last-year's 'bot.
Thanks,
Mike
Unread 16-02-2014, 17:52
Why do you call it the "driver's console screen"? Nothing requires it to be placed in front of the person you call the driver. If the co-driver has more reason to see it, you can certainly arrange things appropriately.
Unread 16-02-2014, 18:16
During the alpha test, there hasn't been anything said about discontinuing the cypress I/O support. The driver station still has all of the appropriate tabs and indicators, although I'm not sure that anyone has actually tested it.
Unread 16-02-2014, 20:07
To this point, the DS, protocol, and many other elements work identically --otherwise we couldn't have a working system for alpha.
The ability for teams to make custom HW to control the robot is not something that will intentionally be left out. But the topology and components may change.
Greg McKaskle
Unread 16-02-2014, 22:22
Software Mentor
AKA: Mike Anderson
Well, we already have rearranged things. But, that stil doesn't address the issue of being able to create a dedicated IO controls box to make the game more playable. We're just looking to see if in the 2015 system "they" have made allowances for digital outputs at the OI. Since the Cypress board has been discontinued, that doesn't look like a viable option moving forward. We currently use the CCI boards for digital and analog inputs and those work great. But, those boards don't support digital outputs.
Unread 16-02-2014, 22:34
ice.berg's Avatar
ice.berg ice.berg is offline
Strategy Mentor & Drive Team Coach
AKA: Alex Bergal
ice.berg has a spectacular aura aboutice.berg has a spectacular aura about
I know on our team we generally don't like looking down at the dashboard during a match. Since when you look down you can lose track of where the bot is on the field and such.
So this year we implemented some onboard 12v LED's that are then controlled with a spike. Then in the program we have the LED's correlated with a sensor on our robot telling if we have full grasp of the ball. So when we have the ball our LED's turn on. This has shown to really help our drivers efficiency on the field.
Your experience may vary though depending on drivers and such of course.
If you need more info on how we did this and what we used dont hesitate to ask!
TEAM 2512 DULUTH EAST DAREDEVILS
'12-'15: Strategy and Build Mentor
'15 Hopper Division Champions and Einstein Finalists thanks 987, 2826, 4265
'15 Minnesota State Champions thanks 3130 and 4215
'15 Northern Lights Chairmans Winner and Regional Finalists & Central Illinois Regional Finalists
'10-'11:Build Captain
'13 Midwest Champion '12 North Star Champion '11 Lake Superior Champion
Website Facebook Twitter Youtube Flickr
Unread 17-02-2014, 08:51
Software Mentor
AKA: Mike Anderson
Yeah, we've done this in the past on our bots as a "skunk works" kind of project. Our mechanicals group never seems to leave any space on the bot for mounting any indicators let alone providing a means to easily wire anything from the sidecar up to a place that such an indicator would live. And, this year's bot is no exception. Only 1" aluminum square channel in the upper structure and the ball comes in on one side and fires out the other. So, very little space to do much of anything. Oh well, there's always next year. Hopefully, the new roboRio will reduce the footprint of the controls hardware enough to allow for more options.
Thanks,
Mike
