Go to Post it's much easier to build safety in to a system than to add it on a Thursday at a regional. - dtengineering [more]
Go Back   Chief Delphi > Technical > CAD
Unread 16-02-2014, 12:34
Chadfrom308's Avatar
Chadfrom308 Chadfrom308 is offline
Slave to the bot
AKA: Chad Krause
FRC #0308 (The Monsters)
Team Role: Driver
Chadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to behold
STL to solid model help
Can somebody please convert this to a solid model? I don't have solidworks or a utility to do this.
Unread 16-02-2014, 12:36
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Re: STL to solid model help
What format do you want?
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 16-02-2014, 12:46
Slave to the bot
AKA: Chad Krause
Team Role: Driver
A *.prt and or *.stp.
Thanks a bunch
Unread 16-02-2014, 13:00
Custom User Title
AKA: Cal
Here you go:
Unread 16-02-2014, 13:08
Slave to the bot
AKA: Chad Krause
Team Role: Driver
I am getting a translation error bringing it into Inventor. Can you make *.IPT? or step please.
Thanks aganin.
Unread 16-02-2014, 13:16
Custom User Title
AKA: Cal
Try this:
Unread 16-02-2014, 13:25
Slave to the bot
AKA: Chad Krause
Team Role: Driver
I don't understand what the problem is, but don't see any geometry from your conversion.
Can somone else give it a try? I need to be able to open this in inventor as a solid and cut parts away.
Thanks again.
Unread 16-02-2014, 13:46
I thought Inventor could open STL files by simply importing them. Am I wrong there?
Unread 16-02-2014, 13:54
Slave to the bot
AKA: Chad Krause
Team Role: Driver
It does. I can open the STL, but it is a surface, not a solid body. I need the file converted to a solid body so that I can edit it like a regular part.
There is an option in Solidworks. When you open the file, from the options menue, you can open as a solid body.
Unread 16-02-2014, 15:20
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
Depending on which version of Inventor you are using, there is a Mesh Enabler application that does what you want.
Here is a tutorial explaining the process.
http://grabcad.com/questions/tutoria...odesk-inventor
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
Unread 16-02-2014, 15:56
Slave to the bot
AKA: Chad Krause
Team Role: Driver
I've seen this, but Mesh Enabler isn't a free download.
Unread 16-02-2014, 19:12
Chad,
I have another team who would like to use Mesh Enabler and am currently trying to get the Inventor 13 and 14 version for teams to use. Should have a reply on Tuesday.
Phil Dollan
Autodesk Inc.
Unread 16-02-2014, 20:48
Slave to the bot
AKA: Chad Krause
Team Role: Driver
Fantastic! Thank you!
Unread 18-02-2014, 15:58
I was able to get Mesh Enabler for 2013. I am running it now to see if the model you posted can converted to a solid.
Will let you know later today.
Phil Dollan
Autodesk Inc.
Unread 18-02-2014, 20:18
Chad,
Check your email.
Phil Dollan
Autodesk Inc.
