Go to Post Ahh! I see that you discovered the "CMD_FLING_RECEIVER_RADIO_ACROSS_ROOM" command in the robot scripting language! Nicely done! - dlavery [more]
Unread 16-02-2014, 14:30
Asymons Asymons is offline
FRC #4716 (Purple Raiders)
Team Role: Driver
Asymons is an unknown quantity at this point
All Motors Flickering Orange
Hi everyone,
My team and I are having a problem with our speed controllers. We were testing a banebot motor and it began to move against the metal. We quickly disabled the program. After rebooting the program every speed controller began flickering orange. We're not sure what the problem is, maybe we fried something. Another note... are banebots able to spin in reverse?
Unread 16-02-2014, 14:42
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Re: All Motors Flickering Orange
Your question is a little hard to understand. What do you mean by "move against the metal"? What motor controllers are you using? Flashing orange typically means that they are not receiving any PWM signal.
Banebot motors can be reversed.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 16-02-2014, 15:00
Team Role: Driver
Sorry, we moved the motor with a piece of metal on it, it was running and then was moving against another solid metal piece.
We are using Banebot R775
Victor Speed Controller 884
Yea the lights were solid before that happened then all the lights started flashing orange after re-enabling the robot.
Unread 16-02-2014, 15:14
Chris_Ely's Avatar
AKA: luckof13
It sounds like there is no PWM signal.
Check an make sure that:
  • The robot is enabled by the driver's station.
  • The PWM cables are plugged in the correct way.
  • The digital sidecar is powered from a 12V terminal on the power board, and all three lights are green.
  • The cable from the cRIO to the sidecar is plugged in all the way.
Unread 16-02-2014, 15:22
Team Role: Driver
We tried all that, ended up swapping the board. Works fine now, Thanks for the help
Unread 16-02-2014, 18:20
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Which board?
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
