Go to Post not national champ.....WORLD CHAMPION - Stephen Kowski [more]
Unread 16-02-2014, 18:59
Iaquinto.Joe's Avatar
Iaquinto.Joe Iaquinto.Joe is offline
RPI 2018
AKA: Joe Iaquinto
FRC #0308 (The Monsters)
Iaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the rough
Potential MotorOuput.vi bug
We've recognized that using MotorController references and their associated output VIs have limited the pwm signall to about 60% maximum values. Although we were sending a 1 to motoroutput.vi, the talon was only outputting about 7V. We switched to a PWM reference, sent 255 to the same channel, and without recalibrating, our talon outputted 12V. We aren't sure if this is a WPILib glitch or if we did something else wrong, but I feel like a potential 40% increase in power may be worthy of a look.
4 year 2011 - 2014 FRC team 308 member, Lead Programmer - C++ / LabVIEW
3 year 2011, 2013, 2014 OCCRA member, Co-Captain OCCRA team 308
  • OCCRA Engineering Excellence - Waterford Kettering 2013
  • Innovation in Control - 2011
  • Quality award- Northville 2012
  • Engineering Excellence- Howell 2014
  • Innovation in Controls- Livonia 2014
Unread 16-02-2014, 19:54
Re: Potential MotorOuput.vi bug
Talons with default calibration respond to a PWM range of 1-2ms. Jaguars with default calibration respond to a PWM range of 0.67-2.33ms. If a Talon was calibrated to run on a Jaguar range, and then fed with a Talon range, it would output around 7v.
The PWM reference uses the full Jaguar range.
Unread 16-02-2014, 20:34
RPI 2018
AKA: Joe Iaquinto
All of the motor controller references were configured to talons correctly using the polymorphic VI. The PWM references allow the talons to reach max voltage, but motor controller references do not.
Oh! Now that I'm thinking about it, we did calibrate the talons on a PWM reference, thus making output strangely. Thanks for the help!
