Go to Post A solution will present itself, all you have to do is be ready to take advantage of it when it does. - James1902 [more]
Unread 02-08-2014, 04:33 PM
GearTech GearTech is offline
FRC #0108
GearTech is an unknown quantity at this point
Axis Camera Help
This entire day, our programming team on 108 have been trying to find ways to access the pictures of the camera and track it. We've been through several documents about the axis camera and programming for vision tracking, but none have either worked or have not been very explanatory. Is there any Documents or Tips about the axis camera and vision tracking anywhere out there?
Unread 02-16-2014, 01:35 PM
Nunez4296's Avatar
Nunez4296 Nunez4296 is offline
Programmer
AKA: Joseph Nuņez
FRC #4296 (Trident Robotics)
Nunez4296 is an unknown quantity at this point
Re: Axis Camera Help
Have you tried RoboRealm yet? I believe as FRC teams, we recieve free copies of the program and you can use this for your vision tracking, then, using network tables, you can port your data back and forth to the smart dashboard. Here is a link for step-by-step instructions. http://www.roborealm.com/FRC2013/slide060.php
Unread 02-16-2014, 07:28 PM
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
The Axis camera provide video in the form of an HTTP stream, which you can access at http://10.te.am.11/mjpg/video.mjpg. Whatever vision processing software you choose to use can use that URL as input. Also, you can type that into a web browser to the feed yourself.
