Go to Post You should qualify the same way you eliminate if you ask me. - sircedric4 [more]
Unread 16-02-2014, 16:19
swaglord2000's Avatar
swaglord2000 swaglord2000 is offline
FRC #4073
swaglord2000 is an unknown quantity at this point
Drawing within the camera portion of driver station
I would like to draw a line on the driver station window camera, so that when the line lines up with the bottom of the goal we know that we can shoot.
Unread 16-02-2014, 16:25
Re: Drawing within the camera portion of driver station
The video is actually displayed in the dashboard program, and it can be customized in several ways. The default dashboard is built in LabVIEW, so if you want it to be the same, except for having a line over it, you can create a dashboard template from the getting started window, then place an object such as a decoration over the video. You can also choose to use an overlay function to draw on the image in the loop.
Greg McKaskle
Unread 16-02-2014, 16:44
FRC #4073
Could you show any pictures? I am very new at programming and no one else knows how.
Unread 16-02-2014, 19:35
If you're not comfortable modifying the Dashboard program, you can try the low-tech approach the TechnoKats drive team has used for the past couple of years. They affix a piece of thin Lexan over the screen and draw on it with a Sharpie.
Unread 16-02-2014, 19:49
BurkeHalderman's Avatar
BurkeHalderman BurkeHalderman is offline
Casual Robot Observer
BurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant future
^This. It's so easy and requires no effort at all. In the past we've used scotch tape to make the cross-hairs on the screen. This is also super easy and works great.
[2010-2014]: FRC 3266 Robots-R-Us: Founder and Alumni
2010 (5-5-1): Buckeye Regional; Driver
2011 (4-5-0): Buckeye Regional; CORI; CAGE Match; Drivetrain/Manipulator Operator
2012 (7-13-0): Buckeye Regional; Queen City Regional; CAGE Match; BPRC; Drivetrain Operator
2013 (25-15-1): Queen City Regional; Buckeye Regional; Crossroads Regional; CORI; Ohio State Champs; CAGE Match; BPRC; Drivetrain Operator
2014 (21-10-0): Crossroads Regional; Queen City Regional; Designer; Mechanical/Design Mentor
Founding an FRC team as an 8th grader sure wasn't easy, but it was totally worth it.
Get in touch with me:
Personal Facebook
I believe every human has a finite number of heartbeats. I don’t intend to waste any of mine. – Neil Armstrong
Unread 16-02-2014, 20:22
Nothing wrong with low-tech, but if you want to learn another way -- the attached photo shows the vision loop modified to draw a horizontal line from 0,100 to 320,100 in red.
You will then need to build the dashboard and choose to have yours run instead of the default. There is a tutorial on the Getting Started dialog about making a custom dashboard.
Greg McKaskle
Name:	From Clipboard.png
Unread 20-02-2014, 20:07
xXhunter47Xx's Avatar
xXhunter47Xx xXhunter47Xx is offline
Lord of Lazy
AKA: Austin $wagmaster1337
FRC #4738 (Patribots)
xXhunter47Xx will become famous soon enough
Man has a point. Why make it difficult on yourself when there's easier methods out there?
Unread 22-02-2014, 11:42
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
If you're using one of the Axis cameras, it's possible to upload a mask to the camera itself. Just create your overlay as a .bmp from Microsoft Paint and upload it to the camera. You'll find menus on the camera for managing the overlay. We've used this several times in the past for putting a vertical, center line on the driver's display without needed to program the Labview dashboard code.
HTH,
Mike
