Team 180 2014 Poor Man's Scouting System
I have posted files for Team SPAM's 2014 Poor Man's Scouting System.
The files can be found here: http://www.chiefdelphi.com/media/papers/2943? The DOC file is for Thursday scouting and is optional. The Data Collection Sheet is available as a PDF files, if you do not want to make any changes, and as a MS Publisher files, if you do, The Excel spreadsheet is the heart of the system. You are allowed to make whatever changes you want to the file. Questions, suggestions, and comments are appreciated. The spreadsheet and Thursday scouting files may be delayed in posting. But don't worry, they will be there soon. I hope..... |
Re: Team 180 2014 Poor Man's Scouting System
I don't see the excel file in the papers can you please upload it.
Warren,
Thanks for posting your sheets. I'm using your effective score method this year. I think it will be a great fit for this game. What values are going to set for aquire, pass, and catch? I was thinking about 10 for acquire and 15 for catch. Also, have you considered counting cycles? In my opinion, average contribution to a cycle plus pace of play have been overlooked by most scouting systems this year. David |
First, BEN35678 the spreadsheet is delayed in being posted by CD. I put in a request last night. It is in the works.
Second, D.Allred you will be able to find the values that we baselined for each item in the Effective Score equations in the ESCoefs tab of the spreadsheet, when it gets posted. We talked about counting cycles, but cycles are alliance dependent, not individual robot dependent. We rely on our "super-scouts" to gather subjective data on teams, such as do they take a long time to pick up a ball. |
Thanks! 1523 has a minor problem where we don't have any returning members the stands and this will help us hugely. O and thanks to mecanum phobia we are alliance captains allot.
#7
For example, our super-scouts might notice a team has a particularly high standard deviation of their effective score. They would then do more research to find out why that is the case. Is their effective score trending upward because they've been adding functionality to their robot? Was there a dip in their middle matches because something broke? Has it been fixed? Most teams do a good job of collecting useful data. It's the sort of problem that can be solved with sufficient manpower. What will set you apart is analyzing that data, drawing useful conclusions. [edit]Does it normally take 2 days for a file to be approved? I can see about hosting the spreadsheet somewhere else if it takes too much longer...[/edit] Last edited by George1902 : 18-02-2014 at 11:52. |
#8
Hi All,
The spreadsheet and Thursday scouting files are posted out in the whitepaper. Thank you Brandon, for figuring out what how to do it. These two files are zipped, so you will have to unzip them after downloading. Sorry for the extra step, maybe this will finally force me to step up to Office 2010. ![]() Enjoy, and I hope you all survived the bag-and-tag night. |
#9
I've updated the Scouting Database spreadsheet. I found a hack in the Standard Deviation equation. If you have already downloaded a copy and do not wish to re-download, be sure to fix the equation. PM me and I can show you how.
#10
Thanks man, I've been waiting for this to show up so I can once again shamelessly steal it and use it.
#11
Will entering a value other than 0 or 1 in the "Ball Preloaded" category cause any issues with the spreadsheet? I'm hoping to fully track teams with multi-ball autonomous modes, including the shots they miss.
#12
The ball pre-load has no input limit, and we only track sums and averages for that piece of data.
However, it might mess up the effective score equation. Look carefully at the coefficients and make sure that you are not double bookkeeping something. |
#13
First off, I appreciate your team posting these every year, I used the system last year and it works great!
Why are some of the coefficients negative in when calculating things like a Low Goal Score? |
#15
The Low Goal Score coefficient is -2 to offset the +3 coefficient for acquiring a ball. You will notice that the High Goal coefficient is 7 instead of 10.
It just helps balance the books. These coefficients were established as a result of a considerable amount of discussion among the scouting and strategy crew. Feel free to modify these coefficients in whatever way you want. That is why we set it up this way. Whatever your scouting and strategy team think is the right way to evaluate a single robots contribution to a match is what you should use. |
