Go to Post Never mind the imperial British Empire, the sun never sets on our FIRST season! - artdutra04 [more]
Unread 17-02-2014, 00:00
atucker4072's Avatar
atucker4072 atucker4072 is offline
Andrew Tucker
AKA: Andrew Tucker
FTC #4968 (Rapid Robotics)
atucker4072 has a spectacular aura aboutatucker4072 has a spectacular aura aboutatucker4072 has a spectacular aura about
Magnetic Read Switches
We just found out that we have to use the magnetic read switches. How so we use them and how do we program for them? Are there any documents already out there on the subject?
Unread 17-02-2014, 00:10
xXhunter47Xx's Avatar
xXhunter47Xx xXhunter47Xx is offline
Lord of Lazy
AKA: Austin $wagmaster1337
FRC #4738 (Patribots)
xXhunter47Xx will become famous soon enough
Re: Magnetic Read Switches
What make/model are the switches? What compiler are you using?
Unread 17-02-2014, 00:16
Andrew Tucker
AKA: Andrew Tucker
I was just about to edit it to say we are using labview. it says mrs- .087 -b
Unread 17-02-2014, 00:21
A typical magnetic reed switch is treated just like any other contact closure sensor. It gets wired between the SIG and (-) pins of a Digital Input, typically the white and black wires of a servo extension ("PWM") cable. In LabVIEW, it is a Digital Input. The value returned by the DIO Get function will be True when the contact is open, and False when the contact is closed.
Unread 17-02-2014, 00:29
Andrew Tucker
AKA: Andrew Tucker
And to use this to stop the cylinder at a certain point you would just stop the flow to the cylinder?
Unread 17-02-2014, 00:41
novamx3 novamx3 is offline
FRC #2502
novamx3 is a splendid one to beholdnovamx3 is a splendid one to beholdnovamx3 is a splendid one to beholdnovamx3 is a splendid one to beholdnovamx3 is a splendid one to beholdnovamx3 is a splendid one to beholdnovamx3 is a splendid one to beholdnovamx3 is a splendid one to behold
You can't use them to stop the stroke at a point... They are strictly for sensing when the cylinder has reached it's end of stroke (or a given point but the cylinder will still continue onto the end of stroke unless it has flow controls and is limited to a very slow travel rate.). Almost all pneumatic cylinders have 2 positions and 2 positions only (typically extended or retracted). If we could use hydraulics we would be talking about lvdts and proportional controls... Alas, it is against the rules!
Ian W. Goodson, CFPPS, CFPHS
Talon Robotics
FRC Team #2502
Lead Mentor
www.team2502.com
Unread 17-02-2014, 00:55
juchong's Avatar
juchong juchong is offline
Electrical Engineer
AKA: Juan Chong
FRC #2655 (Flying Platypi)
juchong is a jewel in the roughjuchong is a jewel in the roughjuchong is a jewel in the rough
As nova stated above, these switches are only to be used to check whether a cylinder is in a certain state. This might be useful for things like: "Is the loader inside the frame?", "Is our launcher completely reset?", etc. Some of that feedback can let the cRio know if you're in a state that's ready to shoot, possibly keeping you from dry-firing.
Teams I've worked with:My Website: http://www.juanjchong.com/
What I do: Analog Devices iSensor Product Engineer
Unread 17-02-2014, 01:12
Andrew Tucker
AKA: Andrew Tucker
So you could control the position as long as the flow is at a very slow rate?
Unread 17-02-2014, 09:38
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
No, that's not how pneumatics work. Even if you shut off the air supply at the solenoid, the air trapped will continue to expand. The only thing that stops a pneumatic cylinder is a physical stop: the end of the cylinder or a mechanical limit.
There is a common misconception that switches, or any sensor, 'stop' machinery. I used to get this in my profession all the time, even from engineers. Sensors do not stop anything. They do not have magical powers. All they do is report on the condition they were installed for. They are feedback, not action. I've seen many expensive electronic switches destroyed in machinery because someone designed them to stop the travel of a mechanical piece and put them in the path of that piece.
Also, it's a REED switch. If you ever opened one up, or looked at a bare one, you'd know why. Two thin, flat ferrous metal blades are trapped in a glass tube with the ends overlapping, but not quite touching. When a surrounding magnetic field induces a magnetic field in the blades, they attract to each other and close the gap. Simple and effective.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 17-02-2014, 10:15
Andrew Tucker
AKA: Andrew Tucker
Alright thank you for the help! I have never worked with the pneumatics before.
