Go to Post I suppose you need to let the kiddies (including Copioli) win a few now and then. - Andy Baker [more]
Unread 17-02-2014, 05:19
Ragingenferno's Avatar
Ragingenferno Ragingenferno is offline
That one guy
AKA: Josh
FRC #3053 (Stingers)
Ragingenferno is just really niceRagingenferno is just really niceRagingenferno is just really niceRagingenferno is just really niceRagingenferno is just really nice
How do I drop pressure below 30 PSI?
I know that the solenoids do not operate after 30 PSI but I was wondering if there was a way to get around this.
Would putting a regulator on the output tubes of the solenoid be legal or even work? That being said, that would allow us to drop the PSI lower than 30 and still have everything operate...right?
Unread 17-02-2014, 06:54
AlexC's Avatar
AlexC AlexC is offline
AKA: Alex Crouch
FRC #5413 (Stellar)
AlexC will become famous soon enough
Re: How do I drop pressure below 30 PSI?
I'm not sure where you get your information about the solenoid valves not working below 30psi. From my experience, they will still fire fine even with no air in the system. I would recommend trying to just regulate down to 30psi first. That being said, I dont believe that there is anything prohibiting regulating the output of the valve.
Unread 17-02-2014, 07:04
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Most of the solenoids we use have to have 20 psi or more to function and change state (Festo, SMC).
I don't know of any rule that prohibits you from placing a regulator after the solenoid to drop the pressure down to what you need.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 17-02-2014, 07:05
Jared's Avatar
Jared Jared is offline
The SMC solenoids need more than 30 psi to operate. I think the Festo ones are a little better, but I'm not sure.
Unread 17-02-2014, 07:08
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
The type of valves that are common in FIRST require air to move the shuttle from one side to the other. Without enough air they can become unreliable or even inoperative.
You can test and see how low you can go and still get reliable operation but Murphy has a tendency to rear his ugly head on the competition field and not in practice.
Perhaps you can tell us why you need such low pressure and maybe the smart people on CD can offer a better solution.
Unread 17-02-2014, 07:47
That one guy
AKA: Josh
I thought I remembered reading somewhere that the solenoids won't operate below 30 PSI.
We are using Pneumatics to pick up our ball and load it onto our shooter. As of right now, 60 PSI is way too much for this. We have a two different pistons controlling X and Y axises. The X squeezes the ball and the Y loads it onto the shooter.
Y piston comes back to hard and hits our mechanism hard. (We don't mind it hitting the mechanism, just not so hard)
We haven't tested X yet but i'm hoping it doesn't squeeze the ball too hard at that pressure.
We have another piston but that one is doing good at 60 PSI.
Unread 17-02-2014, 07:55
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
An alternative you may want to consider is the on cylinder flow control push connect fittings, with this you can dial in how fast the cylinder moves and still maintain the same overall force.
Unread 17-02-2014, 08:05
That one guy
AKA: Josh
Thanks! I will definitely be purchasing those. That will be so helpful. I have to check and see if we have some already though.
So that will slow it down, but it will still be at the same force. We still need the X-Axis piston to be a lot less powerful.
Unread 17-02-2014, 08:11
IndySam's Avatar
What size is your X-axis cylinder (it is not a piston) perhaps you use a smaller diameter cylinder?
Unread 17-02-2014, 08:16
That one guy
AKA: Josh
Originally Posted by IndySam View Post
What size is your X-axis cylinder?
I believe it is 11 inches while intruded. But it stretches the length of the mechanism so changing the size of it will change other factors and we will need to add other things to get the size right. I would prefer this solution as my last resort.
Unread 17-02-2014, 08:32
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
I believe Sam was asking for the diameter. Smaller diameter means less force.....
Unread 17-02-2014, 08:37
That one guy
AKA: Josh
Oh, sorry about that. I believe the diameter is .75-1 inch. I don't see how you can go any skinnier than that.
Unread 17-02-2014, 09:00
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
Big difference of force between 1" & 3/4 bore. Remember the force is proportional to the square of the diameter (or radius)
Unread 17-02-2014, 09:01
IndySam's Avatar
I really can't imagine a 3/4 cylinder having enough force to squeeze a ball to much even at 60psi. Unless you are using massive leverage.
Unread 17-02-2014, 09:12
It might be a bit late, but there are cylinders down to 7/16 bore.
Air piloted solenoid valves from different manufacturers will specify the minimum pilot pressure each requires.
Usually it's between 20 and 30 psi. Just check the spec sheet.
