Go to Post Capability and willingness are two very different things. Anybody can dance, though you could spend your lifetime unsuccessfully trying to convince them of that. - Mr. Pockets [more]
Unread 17-02-2014, 09:12
Re: How do I drop pressure below 30 PSI?
It might be a bit late, but there are cylinders down to 7/16 bore.
Air piloted solenoid valves from different manufacturers will specify the minimum pilot pressure each requires.
Usually it's between 20 and 30 psi. Just check the spec sheet.
