Go to Post The best way to brainstorm is to just do it. - EricH [more]
Unread 17-02-2014, 09:16
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Re: How do I drop pressure below 30 PSI?
Changing cylinder bore will also change the lengths and may impact the overall design.
Adding a regulator to the system between the solenoid and the cylinder you have will reduce the force you are applying.
You can check the rules, and also maybe submit a question to the GDC to confirm.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 17-02-2014, 09:33
Chris is me's Avatar
AKA: Pinecone
We have been firing our SMC 24v solenoids at ~20 and ~30 PSI with no problems. Perhaps it's just the model of solenoid you're using.
Unread 17-02-2014, 09:56
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Regulators after valves are legal
FRC 766, 2015-, Mentor
Unread 18-02-2014, 05:16
Ragingenferno's Avatar
Ragingenferno Ragingenferno is offline
That one guy
AKA: Josh
FRC #3053 (Stingers)
Ragingenferno is just really niceRagingenferno is just really niceRagingenferno is just really niceRagingenferno is just really niceRagingenferno is just really nice
Okay, Thank you everyone.
We are using festo solenoids, ours say, 12/24 volts on them so I guess we can use whatever voltage we want. I can hear mine fire even without pressure. Perhaps they work under 20 PSI like someone said.
We decided to just place a regulator after one the of the values. We lowered the PSI to 45 PSI.
The change in 15 PSI really helped.
Thank you everyone. Now theres just one more problem, but I will start new thread for that one.
Unread 18-02-2014, 10:13
Wren Hensgen's Avatar
Wren Hensgen Wren Hensgen is offline
Alum, Mentor, Volunteer
AKA: Wren Hensgen
FTC #10353 (MetalWorks)
Wren Hensgen is a jewel in the roughWren Hensgen is a jewel in the roughWren Hensgen is a jewel in the rough
Older-style Festo solenoids only require about 17 PSI to fire. If you can deal with a lower co-efficient of flow, I'd recommend Humphrey 310 or 410 series solenoids. They can run on anything above 14 PSI. Getting a narrower cylinder is a good idea as well, we have a few Clippard cylinders with a 3/8ths inch bore. This will give you about 6 lb of force on the output
