Go to Post "No wheels, no problem, we can fix it in programming." - clean399 [more]
Unread 17-02-2014, 12:59
brandon.cottrell's Avatar
brandon.cottrell brandon.cottrell is offline
Vice President
FRC #1266 (The Devil Duckies)
brandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud of
Human Players and Undesired Balls
So it's going to be a bit of a given that some balls may be slightly too inflated or not enough, but still get entered into a match anyway. Knowing that the human player can see the ball prior to it being entered into play, is it possible for the human player to signal that the ball is too inflated, or not inflated enough, and get a new ball on the pedestal?
Unread 17-02-2014, 13:30
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Re: Human Players and Undesired Balls
There is nothing in the rulebook currently for this. Sounds like a Q&A question.
Unread 17-02-2014, 13:50
Max Boord Max Boord is offline
FRC #0179 (The Children of The Swamp), FRC #1592 (Bionic Tigers)
Team Role: Tactician
Max Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant future
i think it would be a better idea if the human player(s) where to decide before the match if it needed to be adjusted. once the match starts, if the ball changes inflation it should be switched out and at least checked for leaks.
