Go to Post However, the best responses come with patience. It might be a couple of days before you get a good answer or it could be 10 minutes. - Molten [more]
Unread 17-02-2014, 14:14
davidfoong123 davidfoong123 is offline
FRC #5180
davidfoong123 is an unknown quantity at this point
Exclamation Victors won't work together.
Hi, our team is having a problem getting Victors to work together. We have 3 victors that are supposed to control different things, but will not run if another victor is enabled in the code. For example, if we have our tension control enabled in the code, it will work. If we un-comment our other routines, maybe something like the catapult launch, catapult launch won't work, but tension control will. If we disable tension control, catapult launch will work. Each victor has worked by itself, but no two victors will run at the same time. The exception to this is that the four victors controlling the motors for driving are always working. Have any ideas?
Here's our code. Some of it is commented out, because we were testing different things.
/* Copyright (c) FIRST 2008. All Rights Reserved. */
/* Open Source Software - may be modified and shared by FRC teams. The code */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project. */
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.Victor;
* The VM is configured to automatically run this class, and to call the
* functions corresponding to each mode, as described in the IterativeRobot
* documentation. If you change the name of this class or the package after
* creating this project, you must also update the manifest file in the resource
* directory.
public class RobotTemplate extends IterativeRobot {
* This function is run when the robot is first started up and should be
* used for any initialization code.
Victor rightall = new Victor(1);
Victor leftall = new Victor(2);
Joystick joy1 = new Joystick(1);
Joystick joy2 = new Joystick(2);
double rightdrive;
double leftdrive;
Victor stickMotor = new Victor(3);
Victor tensionControl = new Victor(4);
Victor catapult = new Victor(5);
public void robotInit()
rightdrive = 0;
leftdrive = 0;
//This function is called periodically during autonomous
public void autonomousPeriodic()
GoForwards();
// This function is called periodically during operator control
public void teleopPeriodic()
Drive();
// SlotThree();
// SlotThreeNegative();
SlotFour();
// SlotFourNegative();
SlotFive();
// SlotFiveNegative();
public void GoForwards()
rightall.set(0.2);
leftall.set(-0.2);
public void Drive()
rightdrive = joy1.getY();
leftdrive = joy2.getY();
rightall.set(rightdrive/2);
leftall.set(-leftdrive/2);
public void SlotThree()
double stickSpeed = 1.0;
if (joy1.getRawButton(6) == true)
stickMotor.set(stickSpeed);
else
stickMotor.set(0);
public void SlotThreeNegative()
if (joy1.getRawButton(9) == true)
stickMotor.set(-stickSpeed);
else
stickMotor.set(0);
public void SlotFour()
double stickspeed1 = 1.0;
if (joy1.getRawButton(7) == true)
//tensionControl.set(stickspeed1);
tensionControl.set(1.0);
else
tensionControl.set(0);
public void SlotFourNegative()
if (joy1.getRawButton(10) == true)
tensionControl.set(-stickspeed1);
else
public void SlotFive()
if (joy1.getRawButton(8) == true)
catapult.set(-1.0);
else
catapult.set(0);
public void SlotFiveNegative()
if (joy1.getRawButton(11) == true)
catapult.set(1.0);
else
catapult.set(0);
/* public void SlotFour()
else
catapult.set(stickspeed1);
else
catapult.set(0);
if (joy1.getRawButton(7) == false && joy1.getRawButton(7) == false)
catapult.set(0);
* This function is called periodically during test mode
public void testPeriodic()
Unread 19-02-2014, 11:23
Re: Victors won't work together.
Are all three of the power LEDs lit on the Digital Sidecar? If you unplug the 37-pin ribbon cable, do the LEDs remain on?
Odd speed controller behavior like this is often caused by the Digital Sidecar not being powered properly. Its power input must be connected to battery voltage through the Power Distribution Board, protected by a 20 Amp snap-action circuit breaker.
Unread 19-02-2014, 22:02
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
I could be way off on this as I wasn't involved in coding this year, but currently our code will only send one button press at a time. Could yours be doing something similar? For instance, can you power two different spikes at the same time? Or a victor and a spike at the same time?
Like I said, sadly I don't know the details of what caused that behavior for us, but your situation sounds similar.
