We have suddenly faced a very weird problem with the programming aspect of our robot. Before I continue, let me state that ALL motor controllers were functioning perfectly as of this morning (~9 AM).
We are still able to communicate with our cRio via ethernet/wireless. We are also able to upload code. However, after our code (which was working perfectly earlier) has been deployed, NONE of our talons receive any input from the sidecar/cRio -- all 9 of them display flashing yellow lights. Spikes are solid yellow. Any ideas as to how we could troubleshoot this issue? We've reimaged multiple times and even switched out old modules. We are really stuck here. The only possible cause of this problem that comes to mind is a short or something similar that fried something downstream. A student dragged a PWM cable across the positive and negative ends of a talon while it was powered causing a small spark -- but I highly doubt that would have caused the problems we are currently seeing. |
Re: cRio communication problems
Nobody touched the PWM cables since 9am?
It's pretty standard troubleshooting to follow the command trail:
Thanks for the response. We have done all of the troubleshooting steps except the ones involving the multimeter. What sort of readings should we expect?
And to answer your question, the PWM cables were disconnected and then reconnected a short time later in the same configuration after we tidied up some of our wiring. |
If the black wire on a PWM cable touched battery voltage on a Talon, you might have fried the reverse voltage protection circuit on the Digital Sidecar.
