Go to Post I know FIRST is all about changing society. But my approach is one person at a time. - Phil 33 [more]
Unread 16-02-2014, 21:33
Team3993Tom Team3993Tom is offline
FRC #3993
Team3993Tom is an unknown quantity at this point
signal light help
OK so the run down is, when I plug the light in the RSL it gos solid but apparently it's supposed to blink. The LED on the RSL is solid green, and again I have been told that it also has to be blink.So what can I do to fix it?
Unread 16-02-2014, 21:35
EricH EricH is online now
Re: signal light help
What state is the robot in?
Unread 16-02-2014, 21:36
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
The light on the DSC should mimic what your signal light does (they're connected internally). Remember to jump the signal light so it's configured for solid light operation, even though the operation is rarely actually solid.
Here are the blink rates, they depend on what mode your robot is in:
Solid ON - Autonomous enabled
Solid ON but blinks off every 1.5 sec - Teleop enabled
Slow blink (900ms ON / 900ms OFF) - System disabled by system watchdog, user watchdog, or driver station set to disabled
Fast-slow (200ms ON / 900ms OFF) - Low battery (<12V) or no user code AND system disabled either by system watchdog, user watchdog, or Driver Station set to disabled.
Fast (200ms ON / 200ms OFF) - System error; no Driver station communication; bad cRIO image, bad team ID, extensive communication errors
Unread 16-02-2014, 23:39
xXhunter47Xx's Avatar
xXhunter47Xx xXhunter47Xx is offline
Lord of Lazy
AKA: Austin $wagmaster1337
FRC #4738 (Patribots)
xXhunter47Xx will become famous soon enough
We found that our problem was solved by switching sidecars. We had the exact same problem until we switched it out.
Unread 16-02-2014, 23:58
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Have you installed a jumper on the signal light? You need a wire running from La to Lb. Without it the light would stay solid.
See R63 C.
The RSL should be blinking in synch with the light on the sidecar.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 17-02-2014, 00:09
Lord of Lazy
See R63 C.
I thought without the jumper the light should be blinking.
Check your sidecar if that light on the RSL port is blinking as well.
Check Ribbon Cable connections, check cRIO connections.
Unread 17-02-2014, 14:18
FRC #3993
At the moment we are not connected to any computer, and the dlink is set to bridge. Our light and RSL is solid. Also could this be happening because of program issues?
Unread 17-02-2014, 14:49
Lord of Lazy
The "code" for the light should be installed on the crio when you image it.
Unread 17-02-2014, 15:12
FRC #3993
ok so what do you think the issue is?
Unread 17-02-2014, 16:01
Lord of Lazy
Check to see if any aluminum shavings have gotten in the sidecar and shorted it.
Have you checked the ribbon cable connections?
Was the sidecar working before?
Unread 17-02-2014, 16:36
FRC #3993
The ribbon cables seem to be just fine, including the side car; but that's whats weird. Ethe only thing that is having an issue is the light.
Unread 17-02-2014, 16:52
Lord of Lazy
Yeah, we had the same problem. We got a new one and it worked. Locked that one up since the "non-functional" one was just having a light problem.
Unread 17-02-2014, 19:47
FRC #3993
we switched out the SC and now it works. thank you
Unread 17-02-2014, 19:48
Lord of Lazy
I suggest you keep the working one sealed up and away if the semi-broken one still sends the correct signals.
