Go to Post Safety is a practice, not a number. - Alan Anderson [more]
Unread 17-02-2014, 15:35
Laxkief9098 Laxkief9098 is offline
FRC #4557
Laxkief9098 is an unknown quantity at this point
CRio waiting to respond
I am a programmer on team 4557 and we are a second year team. Every time I try to deploy any code, the code does not deploy and tells us that it is waiting for the CRio to respond. This line displays twice before sending it into a loop. The driver station tells us that it has communications with the robot, and we are able to ping the CRio. However it does not let us deploy code. This has happened both on this years CRio and the CRio that we used last year. We have searched the forums and tried all of the suggested solutions but none of them offer a permanent fix. We have tried to connect directly to the CRio (not through the D-Link) with an Ethernet cable. Every time we have this problem the final solution that provides at least a temporary fix is re-imaging the CRio. This works for a few times, but eventually the deployment shows the same error.
PLEASE HELP!!!!!!!
Unread 17-02-2014, 15:38
Re: CRio waiting to respond
If you click to the Diagnostics tab of the Driver Station, does it have a lot of errors, or a steady stream of errors? If so, see if fixing those errors helps with the difficulty deploying. Also, look at the Charts tab to see if the CPU usage is very high.
Greg McKaskle
Unread 17-02-2014, 16:00
FRC #4557
The computer's CPU usage is relatively low (10%) and the following errors occurred and I am not sure how to fix them:
Warning <Code> 44002 occurred at Ping Results: link-GOOD, DS radio(.4)-bad, robot radio(.1)-bad, cRIO(.2)-bad, FMS-bad Driver Station
<time>2/17/2014 3:55:33 PM<unique#>17
FRC: Driver Station ping status has changed.
Warning <Code> 44004 occurred at Driver Station
<time>2/17/2014 3:55:32 PM<unique#>16
FRC: The Driver Station has lost communication with the robot.
WHat can I do to resolve these errors because the first error (44002) has always appeared; however the second error (44004) is new.
Unread 17-02-2014, 16:07
If you look at the timestamps, the communications goes down. This means that for over one second, no valid status packets from the robot have arrived. About one second later, the ping is performed, and the radios and cRIO are not there. Without knowing your system, I'm not sure if it is just the cRIO that disappeared or if the radio in-between caused the issue.
Note that the DS doesn't know about intent, and these errors often show up when you reboot the cRIO, deploy and restart, etc.
Greg McKaskle
Unread 17-02-2014, 16:10
FRC #4557
Are there any solutions I can try because the problems continue to persist when I am hardwired into the CRio directly, bypassing the D-Link? How can i fix it if it is the CRio that disappears?
Unread 17-02-2014, 16:31
Can you post a picture of the deployment dialog?
Greg McKaskle
Unread 18-02-2014, 10:18
FRC #4557
The deployment decided to work most of last night and it was not until later that the deployment process failed. I attached a picture of a screenshot. The deployment process failed yet I am able to ping the CRio.
Name:	LabView Problem2.jpg
Unread 18-02-2014, 11:48
chris.boyle's Avatar
chris.boyle chris.boyle is offline
Programming Mentor
FRC #0068 (Truck Town Thunder)
chris.boyle is on a distinguished road
I am also interested in how to get past this particular issue, as we have been seeing this a lot also.
One method that works for us is to start the cRIO Imaging Tool and change the NO APP setting to TRUE and apply. Then deploy the code. Restart the cRIO Imaging Tool and set the NO APP back to FALSE and apply these changes.
2014 Chairman's Award--Michigan State Championship
2014 Chairman's Award--Waterford District
2014 Winner--Great Lakes Bay District
2013 Chairman's Award--Kettering District
2012 Championship Division Finalists--Thanks 330 and 639
Unread 18-02-2014, 13:34
FRC #4557
Is there a solution that fixes it so that we do not have to use the re-imaging tool every time we need to deploy code?
Unread 18-02-2014, 13:38
At this point I don't have a project that shows the issue in a reproducible way. Please contact NI technical support and see if they have suggested solutions, and see if they would like a copy of your project and files so that it can be investigated more thoroughly.
Greg McKaskle
Unread 18-02-2014, 16:05
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
We've seen this occasionally over the past few days in our marathon programming sessions (code, deploy, test, repeat endlessly). If rebooting the Rio/Radio doesn't fix the issue, we then reboot the Computer. Occasionally Windows is the problem.
Unread 20-02-2014, 14:08
Programming Mentor
Greg McKaskle
I took his advice and called NI on bag day, unfortunately I did not have the cRIO in front of me at the time. Tech support was very helpful and mentioned a couple of things to look for to identify the reason for not being able to deploy code.
1) Check for high CPU utilization:
If the CPU utilization is too high it does not deploy code. It pegged at 100% for a few seconds during the start up. Our CPU was running between 35 - 40% after initial start up was complete. This was still too high for our 4 Slot cRIO.
2) Check for CPU utilization with no applications running:
Reformat the cRIO, reboot and run without deploying any code. Check the CPU utilization at this point. We were running at 0%. If there was any CPU utilization, I was supposed to call back before they closed at the end of the day.
I offered a copy of our robot project code to test with. They said due to the many different environments, it would be a very generic test and may not reproduce our situation.
The suggestion was:
A) Use the cRIO Imaging Tool to set the NO APP Switch
B) Reboot cRIO
C) Deploy code
D) Use Imaging Tool to turn off NO APP Switch
E) Reboot cRIO
These steps are also necessary if we want to run the code from a laptop to debug. It is a viable work-around for now. I can imagine this becoming an issue at competitions if we need to redeploy any code in between matches.
Unread 18-02-2014, 16:35
IceStorm IceStorm is offline
Mentor FRC 5046, FTC 8688
AKA: Chad
FRC #5046 (Jacked Up Jackets)
IceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of light
Send a message via AIM to IceStorm Send a message via Yahoo to IceStorm
I was seeing a similar issue this past week. Switched laptops and it got better for a day or so.
Unread 20-02-2014, 07:34
killer_rabbit3's Avatar
killer_rabbit3 killer_rabbit3 is offline
programming rabbit
AKA: Alexander Martinez
FRC #1038 (Lakota Robotics)
killer_rabbit3 is an unknown quantity at this point
Our team has noticed that this happens a lot more often on the FRC 1 cRIO than the FRC 2. We think the problem may have something to do with the cpu usage of the cRIO
