Go to Post My experience in FIRST has taught me that, whatever you do, make sure that no single failure can eliminate half your drive system.[...] The worst feeling in the world is having your robot driving around in circles when there is critical business to be done on the playing field. - Andrew [more]
Unread 17-02-2014, 16:15
Akolbi Akolbi is offline
FRC #4607
Akolbi will become famous soon enough
how to wire the compressor?
I need to wire the compressor and the switch for it. how do i do this? i got the compressor to work, but the switch didn't affect it at all, and it ran while disabled.
what wires do i plug where?
Unread 17-02-2014, 16:19
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: how to wire the compressor?
The compressor is connected to the outputs of a Spike relay. The pressure switch is connected to the Digital I/O section of the Digital Sidecar.
Unread 17-02-2014, 16:23
FRC #4607
what do i connect on the sensor end?
Unread 17-02-2014, 16:27
Taylor Hawkins Taylor Hawkins is offline
2386 BCHS Trojans
FRC #2386 (Trojans)
Taylor Hawkins is an unknown quantity at this point
The sensor connects between the (-) Negative pin and the Signal pin of the digital side car DIO slot that you designate. I believe it doesn't matter what terminal in the sensor the wires connect to, just connect the negative to one terminal and the signal to the other terminal on the pressure sensor.
Hope this helps
Taylor
Unread 17-02-2014, 16:32
cgmv123's Avatar
AKA: Max Vrany
Technically, the C terminal on the sensor should be connected to the GND pin on the DSC and the NC terminal on the sensor should be connected to the SIG pin on the DSC, but it doesn't matter since the switch is just closing a contact.
Unread 17-02-2014, 16:35
2386 BCHS Trojans
FRC #2386 (Trojans)
Thank you for clarifying that. I didn't have one in front of me to give that information.
