Go to Post I'm all for an aggressive game, but lets not crack each others lexan. - Molten [more]
Unread 10-02-2014, 18:09
Zach S. Zach S. is offline
FRC #3307 (Luray Robodawgs)
Zach S. will become famous soon enough
Double solenoid code
I've been trying to wrap my head around this code for two days now and I can't figure it out. I've got the declaration (DoubleSolenoid festo) and the port set ( festo(1, 2)) what is the code for teleop that gives me control of the solenoid, this is the only thing I can't get
Head of Computer Systems and Programming of Team 3307
Unread 10-02-2014, 21:43
Re: Double solenoid code
http://wpilib.screenstepslive.com/s/...ders-solenoids should tell you what you need to know. Briefly, use the Set() method of the DoubleSolenoid class, passing it one of the constant values kOff, kForward, and kReverse.
Unread 11-02-2014, 12:36
My line of code for Set() looks like this
festo.Set(kForward);
festo is the call for our DoubleSolenoid. When i try to build the code I get the following errors:
C:/windriver/workspace/SimpleTemplate/MyRobot.cpp: In member function `virtual void RobotDemo::OperatorControl()':
C:/windriver/workspace/SimpleTemplate/MyRobot.cpp:58: error: `kForward' undeclared (first use this function)
C:/windriver/workspace/SimpleTemplate/MyRobot.cpp:58: error: (Each undeclared identifier is reported only once for each function it appears in.)
Any idea why the Set() I am using is not working?
Unread 11-02-2014, 12:42
Because kForward is a member of the DoubleSolenoid class. Use DoubleSolenoid::kForward
Unread 11-02-2014, 13:30
Sorry, I am a bit new to C++ (recently switched from labview) where is it that I make the ::kForward, is it in the Teleop, or init?
Unread 11-02-2014, 13:47
In the set line that you posted, replace kForward with the text I posted above.
Unread 11-02-2014, 13:48
Thanks, the code built correctly I will try this out on the bot today!
Unread 17-02-2014, 14:07
Okay, tested the program but I still have an issue.
The code seems to be working, I can see the lights on the FESTO changing as I hit the button on the joystick, however, it seems that the solenoid will not fire. Is this a wiring or more code problem? And how can we get this fixed?
Unread 17-02-2014, 14:25
Is it a 12 volt or a 24 volt solenoid? Are you providing it with the voltage it requires?
Do you have enough pneumatic pressure supplied to it for the pilot valve to activate?
Unread 17-02-2014, 16:41
24 Volt, I have the wires running from the solenoid breakout board into the FESTO. And as for pressure we are building it up to 60 for testing, and nothing is firing.
Unread 17-02-2014, 21:52
Just to be certain: Are you feeding the Solenoid Breakout's power input with 24 volts?
Unread 18-02-2014, 09:48
Yes, we have a 20 amp fuse on it, should we be using a 30 amp?
Unread 18-02-2014, 09:59
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Running it through a breaker would only give it 12 volts. 24 volts has to come from the power supply at the bottom of the PDB.
Unread 18-02-2014, 10:30
Right.
The cRIO only uses the first two terminals of the four on the 24v output of the Power Distribution Board. Use the second two to feed the Solenoid Breakout.
(The black connectors show a NC on the third terminal, but the PDB itself provides 24v there.)
