Go to Post Yes, it can. You'll have to ask the lawyers around here whether it's legal or not. - Kevin Watson [more]
Unread 17-02-2014, 16:59
coyoterobotics coyoterobotics is offline
FRC #4565
coyoterobotics is an unknown quantity at this point
Sidecar shuts off when turning left or Backwards
We are having a problem where when ever we try to go in reverse or turn left at more than half speed the sidecar shuts down. Whenever we go forwards and right the drive works fine. Please help us!!!
Unread 17-02-2014, 17:23
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Sidecar shuts off when turning left or Backwards
Is that happening with a fully charged battery?
Unread 17-02-2014, 17:39
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
This sounds like you're drawing too much current when turning. Does the power still turn off on the DSC when you prop the robot on blocks (such that the wheels aren't contacting anything) and you attempt to turn?
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 17-02-2014, 18:27
This problem is noted to happen when the Digital Sidecar isn't properly supplied with 12v power from the Power Distribution.
Check the three power lights on the Digital Sidecar.
All three must be bright green.
Unread 17-02-2014, 18:57
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Remember, the sidecar needs 12V, not 5V
Unread 17-02-2014, 19:55
xXhunter47Xx's Avatar
xXhunter47Xx xXhunter47Xx is offline
Lord of Lazy
AKA: Austin $wagmaster1337
FRC #4738 (Patribots)
xXhunter47Xx will become famous soon enough
Also, make sure motors are set up polarity correct. IE red to M+ black to M-. We had the same cutoff issue when they were reversed.
