Go to Post We never play to lose, or even go easy. We play our best every match. - Paul H [more]
Unread 17-02-2014, 18:11
Team3993Tom Team3993Tom is offline
FRC #3993
Team3993Tom is an unknown quantity at this point
camera
I was wondering if we could use a D-Link camera instead of a axis camera. If yes then do we set it up the same way as the axis?
Unread 17-02-2014, 18:43
Re: camera
There are no rules against using a camera other than the Axis camera.
You'll have to ask a programmer about setup.
Unread 17-02-2014, 18:50
FRC #3993
Re: camera
This is the first time we are using a camera other than the Axis. No one on our team knows how to set it up.
Unread 17-02-2014, 22:06
Re: camera
What do you intend to use the camera for?
The default Dashboard program uses the Axis protocol to get the camera video stream. If you're using a camera that doesn't talk that language, you'll need to do some extra work in order to see Dashboard video.
