Go to Post Both might accomplish the same "function" or "results" (perhaps a lift of some kind), but there are clear differences in simplicity, in cost, in maintainability, extensibility, and several other "ilities" -- which are a staple of engineering evaluation criteria. - msd [more]
Unread 17-02-2014, 19:31
ndroboknight ndroboknight is offline
FRC #3120
ndroboknight is an unknown quantity at this point
Re: Help with Compressor!!!
The relay does currently have a fuse in it. We have tried replacing the fuse of the relay and replacing the relay altogether. I am not 100% sure if I am coding it properly. I have attached the subsystem class for the Pneumatics. And the lights on the sidecar did not come on. Could I know which ones are supposed to come on? Also I want to clarify that I tried to directly power the relay through code, not physically.
