Go to Post We all need to keep things in perspective. When you look back at the entire 2005 FIRST season, is your entire experience defined by the presence of a little cloth flag on the play field? - dlavery [more]
Unread 17-02-2014, 13:31
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Compressor Rule Question
This may have been answered somewhere but I couldn't find it on CD from this year or in the Q&A:
Are we allowed permitted to use an off-board compressor (powered via on-board relay and robot batteries) to fill our tanks pre-match, which is exactly equivalent to a compressor on-board, then use the on-board compressor during the match, or will this violate R79? Only 1 compressor would be plugged in and used at any given time.
This is the proposed setup:
- Prior to match, on-board relay connected to offboard compressor, connected through purge valve
- After filling tanks, disconnect offboard compressor and plug same relay into on-board compressor
The reason I don't see this as violating R79 is because one and only one compressor is ever plugged into the robot (effectively when pumping with the off-board, the compressor sitting on the robot is disconnected and dead weight). This would be equivalent to using the off-board as a spare part.
The reason we wanted to do this is the compressor gets extremely hot, and we want to go into a match with a cool compressor. Adding a large heatsink takes up space and weight.
I consider the setup above equivalent to a scenario in which you fill up tanks with an onboard compressor, that compressor is rendered broken, and a new, cool compressor is introduced as a replacement part prior to the match. Surely this scenario would be legal?
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 17-02-2014, 14:07
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Re: Compressor Rule Question
I would rule that as illegal as you'd be using more than one compressor. It is not the same as replacing a broken compressor because you will reuse the off board compressor for your next match.
Unread 17-02-2014, 15:56
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
I would also call that illegal. You can use one of large fans from the KOP to cool the compressor.
Unread 17-02-2014, 17:00
seg9585's Avatar
AKA: Eric
Okay, fair enough -- but during practice and test off the field (in pits, etc) is this setup allowable as long as the tanks are all purged prior to onboard fill for pre-match setup? My main concern is overheating. I'm okay with running the compressor for 4-5 minutes to fill the tanks and then again during the 2.5 minute match, but while testing these compressors could be on continuously for long periods of time. Far as I know, rules pertaining to the robot config itself apply during matches but not necessarily in the pits or practice field.
My FIRST legacy:
Unread 17-02-2014, 18:52
cgmv123's Avatar
AKA: Max Vrany
The only rules in the pits and the practice field are safety. Make there's always a relief valve and a vent valve on any pressurized system/segment.
Unread 17-02-2014, 19:33
Jaxom Jaxom is offline
AKA: Michael Hartwig
FRC #1986 (Team Titanium)
Jaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant future
If you think that we can violate game rules in the pits, then I should be able to have an alternate pickup arm for the practice field so I don't break my competition arm. When swapping them out would obviously be against the rules.
I do not see the words "on the playing field" in R79. You're only allowed one compressor. Period.
Mentor http://www.teamtitanium.org/
Unread 18-02-2014, 00:54
Mr V's Avatar
FRC #5588 (Reign)
X2
If someone sees you doing it on the practice field they will assume that you are doing it all the time.
Unread 18-02-2014, 01:45
seg9585's Avatar
AKA: Eric
Against the rules? If the arms are identical then I'm not seeing why your example is illegal. T8 clearly describes that mechanisms changed between matches are acceptable if they meet inspection criteria.
Still not sure why such an attitude about the compressor exists here. The rules state you are only allowed 1 and only 1 battery on the robot yet they are changed every match. Why is the Compressor not a replaceable part? This is not an attempt to gain some sort of advantage, its a safety issue.
My FIRST legacy:
Unread 18-02-2014, 02:03
dtengineering's Avatar
AKA: Jason Brett
It seems to me that having a big bag of frozen peas rest on your compressor right up until the moment you walk away from the robot as it sits on the playing field would not only allow you to start the match with a room temperature compressor, but... for what it's worth... a cool compressor.
Heck, you could even leave the frozen peas sitting on your robot... although there may be venue specific restrictions prohibiting you from bringing food into the venue, there are no rules specifically prohibiting the use of cryogenically preserved legumes on the robot.
If overheating is a problem, though, the real solution is to solve the problem... (hmm... deep thought, that one...) perhaps by adding active cooling such as a 12V 'computer' fan that blows a continuous stream of air over the compressor, or by investigating ways to reduce compressor usage.
Jason
Unread 18-02-2014, 05:56
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
R79
Compressed air on the ROBOT must be provided by one and only one compressor. Compressor specifications may not exceed nominal 12VDC, 1.05 cfm flow rate.
R80
Off-board compressors are permitted, however the compressor must be controlled and powered by the ROBOT.
The compressor may be mounted on the ROBOT, or it may be left off the ROBOT and used to pre-charge compressed air in storage tanks on the ROBOT
The intent of this rule is to permit teams to take advantage of the weight savings associated with keeping the compressor off-board. However, using the compressor off-board of the ROBOT does NOT permit non-compliance with any other applicable rules.
Aloha,
Sorry to say, the rules seem to point out that only one compressor can be used by the robot... Yes keeping a spare compressor on hand is wise in case of failure.
I believe if you used on "off board" compressor super cooled as suggested, or had the team fanning it, then install in back on the robot prior to a match, that would be within the current rules.
Though definitely not in the spirit of them.
A lot is thought out for safety during competitions. There are many people and pressurized systems moving around the area. I remember hearing 115psi tanks exploding close by in the pits.. Plastic shrapnel is a bad deal.
Plus many teams are small and vacate the pit when practicing/playing/scouting and having a hot compressor laying about getting possibly knocked over or burning a button hunter is bad... I mean buttons - You gotta gettem all....
We understand your dilemma.. Here in Kona it is about 82 every day, sorry, and dealing with compressor heat, on or off board, is just what you have to deal with..
Good luck this season, and install a fan or two with some shrouding.....
A good teaching moment about thermodynamics.
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Hopper Division | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 18-02-2014, 09:07
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Not legal to use a second compressor or offboard storage.
http://www.chiefdelphi.com/forums/sh...d.php?t=125110
Unread 18-02-2014, 10:11
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
I am not sure anything in the rules would prevent one from using a different compressor to charge the robot when you practice with it. Not saying it would be legal, but I would ask the GDC. The compressor itself is a COTS component. So you could completely unhook it, swap it out, and then swap another one back in. That is not what you are asking, but I would ask the question.
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
Unread 18-02-2014, 12:02
seg9585's Avatar
AKA: Eric
Originally Posted by TikiTech View Post
R79
R80
I just want to point out the wording of the rule.
Compressed air on the robot must be provided by one and only one compressor.
To me, this is different from "Only one compressor is permitted to provide compressed air to the robot" which seems to be the theme of the misunderstanding of this thread.
I interpret the rule as: at any given time, all the air in the tanks, in the cylinders, etc could have only been sourced from a single compressor. If you purge the tanks after practicing, there is no longer any compressed air on the robot so nothing was sourced from your second physical compressor.
The AIR on the robot comes from a single compressor. Not "only one compressor is permitted for usage at a given regional".
Alas, all this is a great excuse for me to go get some dry ice to bring with me to the regional :-). Worst case maybe use the frozen peas approach. I was never intending to harm the button-hunters, as such a compressor would be well shielded and hidden beneath a massive heatsink.
My FIRST legacy:
Unread 18-02-2014, 12:06
seg9585's Avatar
AKA: Eric
Yes, this more or less is what I'm asking (or, at least what I settled on after hearing the rules explanation). "Completely unhooking" is a 2 minute job -- swap the wires, swap the push-in tubing, and remount. Not a bad maintenance task to ensure a cool, healthy compressor in your matches!
My FIRST legacy:
Unread 18-02-2014, 12:09
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
From the inspection check list:
Compressor - Only one KOP compressor (or equivalent, max 1.05 CFM flow rate) may be used (on or off robot). <R79>.
Does not say one at a time. Does not say 2.
