Go to Post Man, Earthquakes all over the place, Volcanos and clouds of ashes, S&Ps down 25 pts! and now 1114 is first seed and going to probably pick 469... yep, id say the end of the world is near - scessama [more]
Unread 17-02-2014, 17:56
ndroboknight ndroboknight is offline
FRC #3120
ndroboknight is an unknown quantity at this point
Help with Compressor!!!
We have the Thomas brand compressor, model number 405ADC38/12. I'm using Java to program the robot. The Compressor seems to just refuse to turn on. I have tried to directly power the relay separately and the compressor still did not power. We know the compressor turns on because we powered it (quite sketchily but only for testing purposes) with a 9V Battery. Please give me some suggestions!
Unread 17-02-2014, 18:00
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Re: Help with Compressor!!!
Do you still have the fuse in the relay?
If so, is the fuse still intact?
If not, replace it with a 20A breaker.
Unread 17-02-2014, 18:08
RamZ's Avatar
RamZ RamZ is offline
Project Manager & Driver
AKA: Ram Zallan
FRC #0004 (Team 4 ELEMENT)
RamZ will become famous soon enoughRamZ will become famous soon enough
Are you sure you're coding it correctly?
Could you either post here or PM me it if you don't feel secure posting it publicly, I may be able to help, we're also using Java this year.
Team 4 ELEMENT
team4element.com facebook twitter instagram
Unread 17-02-2014, 18:55
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Do the relay lights on the DSC come on?
Unread 17-02-2014, 19:31
FRC #3120
The relay does currently have a fuse in it. We have tried replacing the fuse of the relay and replacing the relay altogether. I am not 100% sure if I am coding it properly. I have attached the subsystem class for the Pneumatics. And the lights on the sidecar did not come on. Could I know which ones are supposed to come on? Also I want to clarify that I tried to directly power the relay through code, not physically.
Unread 17-02-2014, 19:36
DDSLoan96's Avatar
DDSLoan96 DDSLoan96 is offline
Jack of all trades
AKA: Danny
FRC #1468 (J-Birds)
DDSLoan96 is an unknown quantity at this point
On the digital side car check to see if you have 3 power LEDS on in the corner and also check to see if you get an indicator light by where you plug in the pwm for the relay. It should be green next to relay 1 based on what your code says
RamZ's Avatar
AKA: Ram Zallan
I don't think you initialized your compressor correctly.
There are four necessary values.
Yours is currently "airCompressor = new Compressor(1,1);"
Ours is basically the same, except the values are (1, 1, 1, 1).
Try that out.
Team 4 ELEMENT
Unread 17-02-2014, 19:51
DDSLoan96's Avatar
Jack of all trades
AKA: Danny
FRC #1468 (J-Birds)
There are three necessary values.
Ours is basically the same, except the values are (1, 1, 1).
Try that out.
I just took a look at the Javadoc for the compressor and I only see 2 constructors, one with 2 parameters(int pressureSwitchChannel, int compressorRelayChannel) and one with 4(int pressureSwitchSlot, int pressureSwitchChannel, int compresssorRelaySlot, int compressorRelayChannel)
Unread 17-02-2014, 19:56
RamZ's Avatar
AKA: Ram Zallan
Yeah, sorry, I meant 4.
I just checked the code and realized that
Edited my above post, thanks!
Team 4 ELEMENT
Unread 17-02-2014, 20:11
DDSLoan96's Avatar
Jack of all trades
AKA: Danny
FRC #1468 (J-Birds)
If Im not mistaken you only need the 4 parameter constructor if you are using multiple digital sidecars
Unread 17-02-2014, 20:12
RamZ's Avatar
AKA: Ram Zallan
Not sure why we use the 4 parameters, but the compressor currently works. Hmmmm...
Team 4 ELEMENT
Unread 17-02-2014, 20:15
DDSLoan96's Avatar
Jack of all trades
AKA: Danny
FRC #1468 (J-Birds)
My guess is that it defaults to 1 and 1 as the other 2 parameters when you only use one card.
Unread 17-02-2014, 20:21
FRC #3120
That was also our understanding. We have also tried the using the constructor with 4 parameters with no luck.
Unread 17-02-2014, 20:23
DDSLoan96's Avatar
Jack of all trades
AKA: Danny
FRC #1468 (J-Birds)
Do you have access to the robot at the moment?
Unread 17-02-2014, 20:24
FRC #3120
No. The lights next to the relay on the Digital Side Car to not come on. We have also tried swapping out the Digital Side Car.
