Go to Post Mistakes happen. It's how we react to them and what we learn from them that shows what type of people we are. - Daniel_LaFleur [more]
Unread 15-02-2014, 17:18
lokistormbringe lokistormbringe is offline
FRC #4681
lokistormbringe is an unknown quantity at this point
Limit Switch Tripping
Our team is currently using a catapult arm driven by two cim motors with a similar configuration to Boom Done's catapult. Currently, we have a wire attached to the large gear at the top to trigger a limit switch that stops the throwing arm. However, the wire keeps bending out of shape. We are looking for something strong enough to trigger the switch but flexible enough to bend around the switch and the frame while returning to the same position. Do you guys have any ideas?
actual pics can be posted later if you need to see the current config.
Unread 15-02-2014, 17:39
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: Limit Switch Tripping
So, you have a throwing arm rotating at a high speed (?) and stopping once a limit switch gets tripped?
I would recommend trying to program your "launch" command to only power the motor for a set amount of time. I'm not a programmer though so I don't know how to implement that exactly.
Unread 15-02-2014, 19:23
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
If you can post what language you're using, I could help you with the programming of the timing operation mentioned above.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 15-02-2014, 21:53
Instead of metal, maybe you can try a strip of lexan? It'll flex but return to its original shape (unless you overstress it).
Unread 16-02-2014, 08:45
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
We used small strips of plastic taken from a plastic bottle (I think it was a liquid Tide container) to do something similar last year.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 16-02-2014, 08:55
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Yes, we need to see what you're talking about. Pictures are always very helpful.
See if you can make it so that the switch will be triggered as the arm approaches the end of it's travel, not when it reaches it. And so that the switch is activated as the thing touching it goes by, not as it runs into it. Hard to explain, but make it so that it works sort of like a cam, pushing the switch from the side, not directly in it's face.
We've had lots of trouble with limit switches in applications like this...so this year we have pneumatics doing all of the arm moving stuff, and the only motors on the robot turn stuff that can keep spinning as long as it wants to
Unread 16-02-2014, 21:17
FRC #4681
We are using java. The current code runs the throwing arm at full until the top switch is hit and them slowly reverses it back into place. It stops when a second limit switch is hit at the bottom
Unread 16-02-2014, 21:37
Whippet's Avatar
MIT Class of 2020
AKA: Luis Trueba
Alright. I'm not too good with Java, but I think the pseudocode for such an operation would look something like this:
if(stick.getRawButton(Trigger) == true){
arm.setSpeed(speed);
timer.Delay(time);
arm.setSpeed(0);
else {
arm.setSpeed(0);
where the variable Time is equal to how long your arm needs to be run, Speed is the power you are applying to your arm, and Trigger is the appropriate button on your joystick. Sorry if this is incorrect, I use LabVIEW and just started learning Java this weekend, but I *think* with some tweaking, this should be what you want.
EDIT: This is for a strictly timing-based solution like SenorZ suggested. I am as yet unsure of how to get the values from limit switches.
Unread 16-02-2014, 23:01
tStano tStano is offline
AKA: Sparks
Team Role: Electrical
tStano will become famous soon enough
A limit switch is a DigitalInput, and its 'get()' may return true or false when pressed depending upon the switch.
It sounds as if you have the code figured out to me. It sounds like you are looking for the mechanical solution to hitting the switch; of which I have none.
But if you need help with code; feel free to PM me and we can work it out some more.
Unread 17-02-2014, 01:25
om_nom_nom om_nom_nom is offline
AKA: Nam
FRC #0708 (Hardwired Fusion)
om_nom_nom is an unknown quantity at this point
Like other people have said, you'll want to trip the limit switch as it passes right before the endpoint, but not at the end point. Momentum should carry it over a bit if you have your motor controllers set to coast, and you can set a timer of some sort to count before it goes backwards. As for what material to use to trip it, try a decently thick zip tie/ wire tie.
Code-wise, it could look something like this in a CommandGroup:
addSequential(new MoveArmForwardUntilLimit());
addSequential(new WaitCommand(0.5));
addSequential(new MoveArmBackwardsUntilLimit());
Unread 17-02-2014, 19:38
FRC #4681
Thanks for the coding help. To trip the switch we are going to go with the plastic idea. We cut apart the bottom of a plastic bin and its tripping the switches just fine.
Thanks guys!
