Go to Post All I wanted was a game hint.... :( - JohnBoucher [more]
Unread 15-02-2014, 18:09
realkingcarl realkingcarl is offline
FRC #0335
realkingcarl is an unknown quantity at this point
Robot Wireless not working
We are able to communicate from the driver station to the robot when tethered, but have no robot communication when connected wirelessly. We found a wireless network 335 (our team number) but when we connected to that network we still had no robot communication on the driver station. So we tried resetting the dlink and re-programming our radio via the instructions at http://wpilib.screenstepslive.com/s/...o-for-home-use but now the 335 network doesn't show up at all!
Any suggestions? We've tried pinging 10.3.35.1 and 10.3.35.5 and both give us the error "destination host unreachable"
Unread 15-02-2014, 18:17
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
Re: Robot Wireless not working
Make sure you set your wireless network connection to 10.3.35.9, and disable IPv6. and for good measures, make sure you disable the local area connection. Also, instead of pinging it you can try navigating to it in a browser by typing into the url 10.3.35.1 Finally, if it still doesn't work, reconfigure your d-link by hard resetting it via the button on the back (hold down for 30 seconds) then use the frc bridge configuration utility.
"Measure with a micrometer, mark with chalk, cut with an axe."
Unread 15-02-2014, 18:40
FRC #0335
Thanks for the help! We tried the above but still didn't see 335 network or have robot communication so we tried resetting the d-link but now we keep getting an error when we try to re-configure the bridge that says "Failed to configure IP Address"
Unread 15-02-2014, 18:43
FRC #0335
I meant it says "Failed to change the IP Address"
Unread 15-02-2014, 21:10
yash101 yash101 is offline
AKA: null
I'd say, reset the router to the default settings. I think it might need to be in AP mode. Once that is set up, you can try again!
Unread 15-02-2014, 22:30
That's your computer's IP address it's talking about. Are you logged on as a standard user rather than as an administrator? Is your Windows system set to a language something other than English?
Unread 17-02-2014, 17:55
AKA: Michael Shires
FRC #0384 (Sparky)
Also make sure that your wired connection is set to DHCP, that may or may not be an issue.
Unread 17-02-2014, 22:40
Joey1939's Avatar
Joey1939 Joey1939 is offline
AKA: Joey Holliday
FRC #1939 (Kuhnigits)
Joey1939 has a spectacular aura aboutJoey1939 has a spectacular aura aboutJoey1939 has a spectacular aura about
It sounds to me like your driver station IP isn't set to 10.3.35.9.
In order for your computer to know how to reach an IP address like 10.3.35.2 (The cRIO), you have to be on the same subnet as the device. The D-link doesn't have a DHCP server so it won't assign you an IP address on the correct subnet.
To fix this you need manually set IP address of the driver station to a correct IP address like 10.3.35.9.
On the driver station go to the 'Network and Sharing Center.' Click change adapter settings. Right click the correct adapter (whatever your wireless card is) and click on 'properties.' Double click 'Internet Protocol Version 4.' Here is where you should set the ip to 10.3.35.9 and subnet mask to 255.255.255.0. You should leave the default gateway and DNS server empty.
If this doesn't work then double check connections between the radio and the cRIO. Re-imaging the radio couldn't hurt and trying to ping the cRIO is a good idea.
Unread 17-02-2014, 23:22
sailorjoe sailorjoe is offline
Mentor, RoboEagles, FWHS
AKA: Joe Hafner
FRC #4579 (RoboEagles)
sailorjoe is an unknown quantity at this point
One thing that hasn't been mentioned. On Windows 7, when you change your network adapter settings, you select the entry for IPv4, and select Properties. Then you put in the DS IP address and subnet mask. After that, click Advanced, and check the list off IP addresses. Make sure that the only one showing is the one you input. If there are any others, delete them. This fixed our problem which had similar symptoms.
Good Luck!
