Go to Post Are we really at the point where the only useful thing we can discuss is Dean's choice in timekeeping apparel? The man has a watch. He uses it to tell time. Do we really care how much it is worth, or who made it? I would be much more interested in what he does, not what he wears. - dlavery [more]
Unread 02-17-2014, 07:58 PM
jijiglobe's Avatar
jijiglobe jijiglobe is offline
FRC #0694
jijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant future
Surgical tubing issues
Our team is using surgical tubing to power our catapult . After a couple hours of testing our surgical tubing seems to be losing power. Is there any way we can avoid this problem (such as stretching the tubing less) that a team knows of or a good alternative to surgical tubing that won't be ruined easily? Thanks in advance people.
Unread 02-17-2014, 08:03 PM
Electrical Engineer
Rookie Year: 1995
Re: Surgical tubing issues
Surgical tubing looses its elasticity if it is subjected to cold. We had a tubing issue at a cold venue once and had to heat the tubing with a hair drier before every match.
BE CAREFUL! Overheating has its own set of negative issues...
Mike Betts
As easy as 355/113...
Unread 02-17-2014, 09:25 PM
Chowmaster4695 Chowmaster4695 is offline
Lathe Master
AKA: Jerry Wright
FRC #4695
Team Role: Tactician
Chowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond repute
We knew this was going to be a very big issue for many teams this year, so we decide to use the better alternative; springs. We are using one 1000lb 5 inch diameter spring with 15 inches of free length and a 12 inch diameter puck. We highly recommend this because of its consistency and power.
Unread 02-17-2014, 10:42 PM
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Depending on how you have your surgical tubing set up it may be "easy" swap to go to exercise bands.
While a bit more of a challenge to deal with due to wall thickness they do come in distinctive force ratings when stretched to twice their original length.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 02-17-2014, 11:45 PM
WeJohnFriedIt's Avatar
WeJohnFriedIt WeJohnFriedIt is offline
Team Captain, Driver
FRC #1466 (Webb Robotics)
WeJohnFriedIt will become famous soon enough
Team 1466 is using a similar system, and we have had success just loosening the tubing when we don't need to shoot. If that doesn't help, you may want to use something easily removable like S-hooks to attach the tubing.
John Fry
Team 1466, Webb Robotics
Unread 02-17-2014, 11:58 PM
BBray_T1296's Avatar
BBray_T1296 BBray_T1296 is online now
I am Dave! Yognaut
AKA: Brian Bray
Surgical tubing works best if not stretched more than 2x its length. It is supposed to retain its structure longer.
Also, if you have a bundle of tubing, they may rub against each-other (especially during rapid retraction) and wear in that way
Other than that, I would leave it to normal wear and tear. A couple of hours is not unreasonable for something like elastic tubing. Maybe just bring enough to a regional for 3-4 replacements?
Unread 02-18-2014, 12:09 AM
rcmolloy's Avatar
rcmolloy rcmolloy is offline
AKA: Robert Cory Molloy
rcmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond repute
I wouldn't say that your surgical tubing isn't losing power but more on the side that you're having the tube elongated out of its clamp. This would decrease winch elongation and therefor the force to shoot. What you might want to look into doing for your surgical tubing is clamp it using a capstan. It essentially uses the friction around a corner, cylinder, or any surface to relate to clamping force.
Here's the wikipedia page about it all!
http://en.wikipedia.org/wiki/Capstan_equation
FRC 1647: Iron Devils - 2009 - 2011
FRC 973: Greybots - 2011 - 20XX
"While I was a student in FIRST, it was all about becoming inspired. Now as a mentor/engineering student, it's all about making sure learn everything I can so I can carry that on inspiration for future generations while having a hell of a lot of fun!"
Unread 02-18-2014, 12:15 AM
nxtmonkeys's Avatar
nxtmonkeys nxtmonkeys is offline
SCP-682
AKA: Parker Wells
FRC #5349 (RoboEagles)
nxtmonkeys will become famous soon enough
Lightbulb Re: Surgical tubing issues
U can also use more if u have it.
Unread 02-18-2014, 02:54 AM
david cobbley david cobbley is offline
David
FRC #4488 (Shockwave)
david cobbley is an unknown quantity at this point
Our team ordered the black tubing from Mcmaster mostly for aesthetic purposes but they appear to hold their elasticity longer than those supplied in the kop, we will probably change them out once or twice during a district though to be on the safe side.
David Cobbley
Programming Mentor
Team 4488
Unread 02-18-2014, 10:18 AM
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
It really depends on how much you're currently stretching your tubing. Once stretched far enough, any material will begin plastically deform (permanently stretch) rather than elastically deform (stretch and then return to original length). Once you pass this yield point, each stretching cycle will cause a slight amount of permanent deformation, resulting in longer (and thinner) tubing, which will be stretched less in the future (thus resulting in less force). One solution to get the same amount of force would be to use more (or thicker walled) tubing, with each band stretched less. Another would be to periodically replace the tubing with new tubing.
Unread 02-18-2014, 10:51 AM
ice.berg's Avatar
ice.berg ice.berg is online now
Strategy Mentor & Drive Team Coach
AKA: Alex Bergal
ice.berg has a spectacular aura aboutice.berg has a spectacular aura about
Our team is using 5/16" OD 3/32" wall surgical tubing. We found a force calculator online for surgical tubing and found that most surgical tubing is most efficient in the 300% stretch range. We then based our design around that.
As for the lifespan of the surgical tubing we have found it is good for about 100 shots, but only because of the small nicks and cuts it had in in because of some sharp pieces on our robot. After replacing the tube, we compared an old piece and a new piece and found that the old piece only stretched an extra inch after about 100 shots.
We do know of the issue of temperature, being from Minnesota this is definitely on our minds as outside temps are just a little bit different from the inside temps... So we just make sure the robot is properly warmed up before we start testing and practicing.
The force calculator can be found here: http://www.primelineindustries.com/tools.html
TEAM 2512 DULUTH EAST DAREDEVILS
'12-'15: Strategy and Build Mentor
'15 Hopper Division Champions and Einstein Finalists thanks 987, 2826, 4265
'15 Minnesota State Champions thanks 3130 and 4215
'15 Northern Lights Chairmans Winner and Regional Finalists & Central Illinois Regional Finalists
'10-'11:Build Captain
'13 Midwest Champion '12 North Star Champion '11 Lake Superior Champion
Website Facebook Twitter Youtube Flickr
