Go to Post Getting a swerve to drive predictably and effectively is arguably harder than designing and building it. - Holtzman [more]
Unread 18-02-2014, 00:01
Ginger Power's Avatar
Ginger Power Ginger Power is online now
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Gearbox Question
We are having trouble winching down our catapult. We currently have a toughbox mini with 2 mini cims in it. We have the ability to put 2 cims in it but we are currently pretty far from the power we want to have for our catapult (like halfway or less to our goal and the motors stall out). We also have a reduction after the toughbox mini with a 19 tooth gear driving a 48 tooth gear. I wanted to know of any gearboxes that really gear the motor down and offer a lot more force. Also if the difference in power between cims and mini cims is significant enough could this solve our problem? If you could post a link to the website for the gearbox it would be greatly appreciated.
Unread 18-02-2014, 00:27
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Gearbox Question
The mini Cim has about 2/3 the torque of the full size CIM
Spool size is also part of the equation...what are you using to wind up whatever it is you're pulling?
Unread 18-02-2014, 00:36
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Also make sure that your winch release isn't slowing you down-- we found out at our week 0 this weekend that the winch we were using (a COTS boat winch) was introducing so much friction when we released that it cut our shot length to 25% of our new version.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 18-02-2014, 08:38
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
We made our own spool and it has a 2" diameter. Right now it is really holding our shot back but we plan on decreasing the rolling friction it has. Do you think that by decreasing the spool diameter that will significantly help?
Unread 18-02-2014, 09:00
MrForbes's Avatar
AKA: Jim
Decreasing the diameter will increase the force applied to what the winch is pulling. But it will also increase the time it takes to move it.
Unread 14-03-2014, 12:18
golucky66 golucky66 is offline
FRC #4055
golucky66 is an unknown quantity at this point
Team 4055 had a problem with tensioning our catapult. I don't know exactly what is a problem with yours but we had a few issues.
1) We had one CIM tensioning the catapult
2) There was a large amount of friction because we didn't use bearings (Bad decision)
3) We were applying force to our arm at an extremely small angle.
Fix
1) We designed a completely bolt on mechanism. It was a 4.5 to 1 ratio with two CIMs.
2) We upgraded to a 1/2 in keyed shaft with Oil Impregnated Bronze Bearing
http://www.amazon.com/Spyraflo-PB1-5...bronze+bearing
3)Force has it's maximum efficiency when the force is applying perpendicular to the arm. Relocating our attachment point for our winding strap helped.
Unread 14-03-2014, 12:31
TheKeeg's Avatar
TheKeeg TheKeeg is offline
Michigan Tech Engineering
AKA: Keegan Harrington
FRC #0068 (Truck Town Thunder)
TheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud of
On our winch, we used an RS 775 with a 1:100 versa planetary gearbox (1/2 inch Hex output). We estimate that it takes about 50-75 lbs to pull the catapult back and it does so in roughly 3 seconds.
P.S. Our spool has a 2 in OD
Keegan Harrington
Truck Town Thunder
2013-2014: Mechanical Design
"Infinity: you empty out all of the coffee and there is still more orange juice"
Unread 15-03-2014, 13:03
nixiebunny nixiebunny is offline
AKA: David Forbes
FRC #4183 (Bit Buckets)
nixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond repute
Our winch works great! Here's what we did.
We use a VexPro 2 speed ball shifter, with the balls removed from high gear to convert it to neutral. We power it with two CIMs. (We first tried mini-CIMs, but swapped out one of the three CIMs on each drive gearbox with the miniCIMs.)
We use a VexPro 1/2" hex shaft for winding the 1" wide military-grade webbing that pulls down the catapult arm. The shaft fits right into the end of the gearbox.
The most significant thing we did for reliable winding is that the webbing is anchored to the shaft at a point about 2" away from the final winding point, so that it winds helically along the length of the hex shaft instead of in a single roll. This dramatically reduces the final diameter of the wound-up strap, resulting in a much lower effective gear ratio at the end of the stroke when the tension is the highest.
--David Forbes
Mentor, Bit Buckets team 4183. Assistant cat herder and dispenser of legendary tales.
Need a Nixie watch? Yes, you do. Ask me.
