Re: imaging tool does not see modules
Originally Posted by Team3266Spencer
A crossover cable is not necessary. Or so I've been told by multiple mentors.
It's easy to be fooled. The Imaging may partially work, but fail to complete, without a crossover cable - I saw it happen this season. Best connect a crossover cable directly from the cRIO (port 1 on the 8 slot one), to your computer.
I've also seen Imaging fail with the computer not on the same subnet, again running partway. The imaging tool will show the IP address of your cRIO but not complete. In this case, change the computer's IP address to the same first three
dotted numbers (eg, if the imaging tool gives the IP address as www.xxx.yyy.zzz, set your computer's IP address to www.xxx.yyy.zzz+1, for example. Hopefully the Imaging will complete, then set your computer's IP address to 10.te.am.5, etc.
Silicon Valley Regional 2005, 2006 972
Silicon Valley Regional 2007 668 Xerox Creativity Award
Championship Event 2007 668
Portland Regional 2008 668
Silicon Valley Regional 2008 668, 972
Beta Test Team 2008 668 (with 100 & 254)
Silicon Valley Regional 2009 668 Regional Chairman's Award; 2643
Sacramento Regional 2009 668 Winning Alliance (thanks, 1717 & 2473!), 2010 Winning Alliance 3256
CalGames 2006, 2007, 2008, 2009, 2010, 2011 Field Tech
NorCal FTC Regional 2008, 2009 Inspector
Championship Event 2009
San Diego, Silicon Valley Regionals; Champ. Event 2010 668, 2643, 3256
Silicon Valley, Madera Regional 2012 2643
WRRF Programming Instructor 2006-2016
Regional Woodie Flowers Award 2014 2643 Utah Regional
